Question about Pc Ware PCCHIPS M585 LMR Motherboard
I need the manual of the motherboard because I need to put a usb port
  • 477 Answers
Hello, go hereand choose your model. you find your manual here.
Posted on Feb 23, 2009
Usb port don´t work, if you connect this says "no se reconoce dispositivo usb" but sometimes this work perfectly
it happened probably due to a virus. Has you scan your computer with anti virus. I suggest you use the Kaspersky virus remover tools. If the problem on your usb ports are still repeated, it is possible that you put things like USB cable, pen drive or the like that is put into the usb port or usb you probably can not be fully functional.ways to overcome this problem is much better to install a USB card to pci slot on your motherboard.
Jul 20, 2010 | Asrock ConRoe1333-D667 Motherboard
Acer Veriton 3600GT motherboard - sound/usb not connected
Use the link below to download the manual for your motherboard. http://support.acer-euro.com/documents/manuals/desktop/manual_veriton_3600gt.html
See page 54 for your motherboard layout.
Apr 11, 2010 | Acer Veriton 3600GT PC Desktop
When i plug in my memorycard adapter into the usb ports .the baloon says i need a hispeed usb host controller.
The memory card you have is for a USB2 configuration and the USB port configuration or port you are using is USB1 configuration.
Try a different port or check the manual for port layout or description.
Sep 26, 2009 | DFI WB72-SC Motherboard
Problem with USB port on Asus P5KPL-AM SE Motherboard
Older motherboards have USB 1.1 ports;
newer motherboards have USB 2.0 ports,
which are over 10 times as fast.
It is Windows (not your motherboard) that should do the "Plug-and-Play" thing for devices connected to your USB port(s).
Note that some devices are USB 2.0, and will *NOT* work when plugged-in to a USB 1.1 port.
Either get a newer motherboard, or get a PCI add-on card that adds USB 2.0 ports.
Sep 10, 2009 | ASUS P5KPL-AM SE Motherboard
Usb ports loose and now wont work
Even taking a laptop apart (to board level) is tough, but you need to order the USB socket on ebay and solder the new one in carefully. Are you a qualified miniature soldering expert?
Jun 30, 2009 | Dell Inspiron 8600 Notebook
QDI kudoz 7 mauanl wanted
this time your got have a spammer, i tell you read the USB port at the motherboard then put the wire connection there
Jun 17, 2009 | QDI Group QDI KuDoz 7 Motherboard
Front usb ports
Have a computer store look at it they may be able to help you put the wwires in the corect spot.
May 03, 2009 | XG Viper 2 ATX Mid-tower Gaming Case...
PS 2 port problem
What is the model number of your motherboard? VIA does not make Processor's/CPU's.
VIA makes chipset's for motherboards.
In order to answer your question I'll need the manual for the motherboard. No manual listed here: http://www.via.com.tw/en/products/mainboards/others/p4xb_m.jsp
Here is a picture of the VIA P4XB-M motherboard. This model can not use DDR2 memory. (Only, 184pin PC2100 DDR266 DIMM)
Found here: http://www.upgradecomputermemory.com/ram.cfm//memory/V/VIA-Technologies/P4XB-M-Motherboard/256MB-VIA-Technologies-Desktop-184pin-PC2100-DDR266-DIMM.html
VIA P4XB-M
http://www.via.com.tw/download/mainboards/4/11/P4XB-M.pdf
99.0% of motherboards still use PS2 ports. One colored purple for the PS2 keyboard female port, back side of the MB & the other colored light green, female port, back side of the MB PS2 mouse port. By default, most motherboards have the jumper for PS2 keyboard enabled. Location for this two-pin jumper varies from board to board.
A USB port looks like this:
http://www.rickysays.com/images/usb-port.jpg
The PS2 port's are found in the upper left hand corner of this same picture. This next link will show how to connect USB motherboard jumpers including their wire locations. (Standard for most motherboard USB connections).
Mike
Dec 15, 2008 | VIA P4XB-M Motherboard
Pc Ware PCCHIPS M585 LMR Motherboard Logo
140 people viewed this question
Top Pc Ware Computers & Internet Experts
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
