Question about Lexmark X5150 All-In-One InkJet Printer
Unlock scanner keeps appearing on my lexmark x85 printer
I recently moved to another state and unpacked my printer. When I connected everything again, the printer said "unlock scanner". The red lock/unlock switch is unlocked and always has been. Nothing will work on the printer now except turning it off and on. I have uninstalled and installed and it still says unlock scanner.
  • Anonymous May 15, 2009
    i can not print anything from the printer it says unlock scanner
  • 109 Answers
Go to the Lexmark web site here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
- In the SEARCH BY MODEL box, type in X85 and click SEARCH
- In the SEARCH THE KNOWLEDGBASE box, type in UNLOCK SCANNER. It will show some instructions for the X83, but that was the little brother of the X85, so should work.
Steve
Posted on Feb 25, 2009
MY LEXMARK X5150 UNLOCK SCANNER
Posted on Aug 30, 2009
My lexmark X85 printer is locked cant move switch to unlock
It could be that the lock mechanism has gone bad. Please contact Lexmark technical support center for assistance.
Aug 31, 2011 | Lexmark X85 All-In-One InkJet Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
On a Lexmark x85 printer how do you unlock the scanner?
Push the red button down that's found behind the printer to unlock the scanner. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 11, 2010 | Lexmark X85 All-In-One InkJet Printer
Lexmark x85 multifunctional, not recognize cartidrige color
The cartridges are only installed through the printer itself and there is no installation of cartridges through the Lexmark software. You should ensure the Lexmark X85 has the cartridges installed in stand-alone mode. To do so, please follow the steps given below:
1. Push the "Menu" button 10 times, until "Maintenance" appears.
2. Then hit "Select" and "Change Cartridges" should appear.
3. Hit "Select" again. It will prompt you to open the lid and change the cartridges. Please do so.
4. When the lid is closed, the display will ask you if new or old cartridges were installed. If new, it may ask you to align the cartridges and you should do this too.
If it is not noticing a change, remove and reinsert the cartridges about 3 times in a row to re-establish pin connections. If this still presents you with a "Change Cartridge" or "Low Ink Level" message or something similar, try a different cartridge.
Oct 17, 2009 | Lexmark X85 All-In-One InkJet Printer
I need to install a lexmark x85 printer scanner
If you need to download the software/driver, go here: http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Search for your printer (X85), then select your operating system and language. After you download the file, double-click it to launch it and follow the instructions on your computer screen.
I think you just need to install the software, but if you also need to set up the hardware, refer to the instructions in the Setup Sheet, which you can find here: http://www.lexmark.com/publications/pdfs/x85/en/setup.pdf
Follow the instructions on the Setup Sheet through step 13. At step 14, rather than inserting the CD, download and install the software as I've instructed above.
Oct 01, 2008 | Lexmark X85 All-In-One InkJet Printer
I HAVE NO DISK FOR SETUP FOR PRINTER SCANNER FOR X85
this i presume is a lexmark x85
i presume you have windows xp or vista on your computer
if you have not tried windows setup wizard to install the scanner please do so .if its not listed or found then either go to driversguide.com where you can signup for free and download a few drivers for free or go directly to lexmark
alternatively you could email a seller of an x85 at an online shop/auction site like this link http://peterborough.kijiji.ca/c-buy-and-sell-computer-accessories-Lexmark-X85-All-in-One-Printer-Scanner-Photocopier-W0QQAdIdZ42295454 and maybe the guy might be able to email you the files needed
hope this helps.haemox
Mar 27, 2008 | Computers & Internet
Vista Lexmark X85 printer/scanner compatability issue
vista cant find lexmark X84 drivers on install disks,need replacements
Feb 20, 2008 | Computers & Internet
Lexmark x85
You didn't specify which operating system you have.
If you have Vista, people have reported success using the Windows 2000 driver.
Drivers can be downloaded from here:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X85
Feb 09, 2008 | Office Equipment & Supplies
Lexmark X5150 All-In-One InkJet Printer Logo
488 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
