Question about Reddy Heater-30-55,000 BTU Variable
Reddy Heater R50A will not ignite
Reddy Heater R50A, the heater blows fuel but will not ignite. I am assuming the ignitor is bad. Is there an easy way to check the ignitor?
  • 181 Answers
Yep.plug the unit in and look in the back of unit.should see an orange glow.if you don't the glow bar is not comming on
Posted on Feb 23, 2009
I got a reddy heater R50A, a hand me down from my Dad. I don't have a manual. I plug it in and the fan starts but it doesn't ignite. I filled it with new fuel before I started.
Here is a service manual for the heater.
http://www.desaparts.com/service_manuals.html
You first need to check for spark on the unit. If you have spark then make sure you have air pup pressure coming from the air pump / rotor on the back of the motor.
If you have other questions we can try to help.
Thank you.
M Cramer
www.allpartsinc.com
Jan 04, 2011 | Heating & Cooling
I have a lp 75-125 reddy heater. when pluged in it no longer sparks to ignite fuel. I have the style were the ignitor is always sparking an arc.
The tranformer that sits under the motor for the igniter could be burnt out. You can use an ohmmeter to check it. I'm assuming yours has a spark plug. Make sure it isn't fouled and has a gap of .050".
Dec 25, 2010 | Reddy 30m Btu Lp W/th Heater
Heater will not stay on rm60 reddy heater
When you say the heater is coming on does it actually ignite or is the motor just running until the safety circuit kicks it off? The air pump on you heater should blow at 3.5 to 4 psi which runs up to the nozzle which is a venturi which sucks the fuel out of the tank. The motor will generally run for 20 to 30 seconds trying to ignite. If the flame sensor does not sufficient flame during the time it shuts the motor off. Check these items and let me know what you find.
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Pro 115 Reddy Heater
The ignitor is bad, there are still parts available from reddyparts.com very simple to install.
Jan 24, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
When heater starts it does not always light, I get a C3 code
the ignitor is faulty, mine also did that and I noticed one night that it was shorting out right from the ignition box. I put in a new ignitor and flame sensor and it's fine now. All ignitors are basically the same you just have to do some creative wireing. reddyparts.com still has most parts for your heater.
Jan 20, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
R155A Reddy Heater Help!
This is going to be a tough one. You have been thorough, done it right, and it damn sure ought to fire off every time!
There is something that is causing you a problem and don't think that because you put in new parts that you didn't get a bad part. It happens. Not often, but it does happen. I have rec'd nozzles from the factory that had the orifice installed sideways, so, I know it happens.
If the ignitor glows- (it only stays on for 5 seconds, then quits)
If the fuel fogs (not sprays)
If the fuel hits the glowing ignitor
Then it should fire off-- every time.
Now, if the photocell doesn't like what it sees, then the photocell will shut the heater down within 5 seconds, but it at least should have ignited. Right? Unless the photocell or the board are bad. Maybe.
Lift the top, and watch. What's happening. Are you having a fuel problem or an electronics problem? For instance- is the ignitor glowing every time at start up or only sometimes.
Let me know what you find.
Jan 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
REDDY HEATER 125T WON'T INGNITE
  1. Does the ignitor glow for 5 seconds when the unit is started?
  2. What is the air pump pressure reading?
These are the starting points for troubleshooting a heater that has an ingntor.
Answer these questions and maybe someone can get you started.
Dec 16, 2008 | Desa International RH125AT Utility Heater
Trys to start. Motor turns slowly (revolution in 2-3 seconds).
Either:
  1. the reset (safety control) is bad
  2. the photocell is defective
  3. both of the above
To test the photocell http://reddyparts.com/photocell_test_sp.htm
Nov 29, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
579 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
