Question about Car Audio & Video
Autotek Third Octave Equalizer. Model#7006 Need wirering diagrm for this equalizer. It has a plug of 9-pins input. Need to know which one is power, ground, and remote. Please give me information as soon as possible. U can reach me at www.gdang101@aol.com Thank you
  • Anonymous Mar 31, 2009
    Same thing.
  • 28 Answers
SOURCE: alpine equalizer wont work
to have them work you have to connect the yellow wire to constant 12 volt power,and the red to blue and white wire coming from the radio if you dont have a blue remote wire on the radio connect it to the accessory of the car wire that power the radio
Posted on Dec 04, 2008
kias
  • 25 Answers
SOURCE: Power Acoustik Equalizer PWM-30
i don't know about the availability of boschman but it's the best.
Posted on Aug 27, 2008
blueextc3221
  • 15935 Answers
SOURCE: need wire diagram for clarion 500EQA equalizer
Your installation manual is not anywhere to be found since the product you are inquiring about was made 1985-87... however, by deduction, you can figure it out yourself...
You need a Power 12V Constant.
A 12V Switched
A Ground
And Signal Cables.
Reply with the wire colors available to you, and I will tell you what is what.
Yellow is usually constant 12V.
Red is Ususally switched 12V.
Black Is Ground.
RCAs are self explanitory.
If your EQ has HI Level outputs, the color scheme is a little more complicated.
Posted on Jan 10, 2009
MrScary66613
  • 1990 Answers
SOURCE: need info on wiring for audiobahn aeq6q 5 band equalizer
Yes, This connects to the Blue Remote Wire. This will allow the EQ To Power on when in ACC or Start on the Ignition. Please Rate My Response! Thanks!
Posted on Feb 03, 2009
rteemon
  • 578 Answers
SOURCE: wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
Posted on Aug 07, 2009
How do you connect a home pioneer graphic equalizer sg-9 to a sansaui r-7 receiver?
Use the tape monitor loop. Connect from the TAPE REC output on the receiver to the INPUT on the equalizer and from the OUTPUT on the equalizer to the PLAYBACK input on the receiver. YOU can then switch the equalizer in and out using the TAPE MON switch. I think the Model Seven had two tape loops, so just keep everything on the same loop.
Aug 03, 2014 | Audio Players & Recorders
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
I wanna equalizer a jensen 760 but i can`t can you tell me how can i do?
Hello, if you want to put an equalizer on an amp then I would suggest you get a preamp style equalizer, non powered of course, take the rca output whichever one you want to use and conect it to the input on the equalizer. Then take the output from the equalizer and hook it up to the input on your amp. That's it. Most equalizers also have sub outputs, make sure you hook the correct output from the equalizer up to your amp. Also most have 3 outputs depending on the type you have. If you need more help just let me know, good luck
Aug 14, 2009 | Audiovox Jensen Power 760 Car Audio...
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Jul 07, 2008 | Car Audio & Video
Jul 04, 2008 | Power Acoustik PWM-30 Car Equalizer
Power connection
look at the back it should show you
power, ground and remote
Jun 05, 2008 | Kicker 03KQ9 9-Band Car Equalizer
HOOKING UP???
im looking of wiring diagram of proline equalizer model GP-870XII
pls can i have a favor to send at my yh act serra_ricky@yahoo.com
tnx!~ and more power!
Sep 15, 2007 | AudioControl EQL 13-Band Car Equalizer
Power connection
Theres supposed to be a harness that plugs into that connector. It will have the international color standard wires. Contact a kenwood dealer to get the harness.
Sep 14, 2007 | Kenwood KGC-6042A 9-Band Car Equalizer
Car Audio & Video Logo
211 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
