Question about Panasonic VDR-M53 DVD Camcorder
FINALIZE DISC DO I NEED TO FINALIZE MY DISC TO PLAY IT ON MY COMPUTOR;; IF SO HOW DO I FINALIZE THE DISC
  • 4 Answers
Power on the camcorder. Push the disk navigation button, then the menu button. Scroll down until you find the option to finalize disk. Follow the instructions on screen. You will need to have it hooked up to the ac adapter inorder for it to work. Good Luck!
Posted on Dec 12, 2009
How do I get my dvds to play on computor after finalizing disc.
Hello!
1) Are you sute that the DVD are finalized?
2) For me, it works either on tv and on computer. And if your DVD are readable on TV, it prooves the problem is not from your Toshiba DVR620 machine.
3) Maybe a problem on your computer?
A lack of codecs for your video player software ?
Try this for free: a pack of codecs DIVX, and it comes with a free video player and video converter software : http://www.divx.com/en
4) You can try also the video player VLC, it is free, and it reads almost everything! (It's a lot better than Windows Madia Player...)
http://www.videolan.org/vlc/index.html
5) Maybe the problem is in your hardware DVD player ?
If the autorun does not launch automatically, look at this tutorial :
Why does nothing happen when I insert a disc?
http://ask-leo.com/why_does_nothing_happen_when_i_insert_a_disc.html
Hoping these cues can help... ;-)
Jun 16, 2014 | Toshiba DVR620 DVD Recorder/VCR
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
After burning my DVD-R, I can not play it on my computor or any other DVD player. What am I doing wrong?
Did you finalize the disc? How you do this will depend on whether you are using your computer or a standalone DVR. On XP, I had to tell my burning software to finalize the disc after burning. On Windows 7, I find it will finalize the disc on eject (until I changed that setting). Finalizing the disc is an option under right clicking when I have a disc in the drive.
On a standalone DVR, you should find an option to finalize the disc in the menus that let you write a title to the disc.
Without finalization, other dvd players will not be able to read the disc. You also need to make sure that the disc is compatible with each player (+/- R is not universal).
I hope this helps.
CIndy Wells
Dec 09, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvdr3576h will record on dvd+r but will not play on other devices
You will need to finalize the discs on the Philips. I know the manual says that +r may auto-finalize, but I found that finalization sometimes fails on the first attempt. Go into the menu for the Philips, and select the Edit Disc -> Finalize option. Once finalized, your disc should play in other players.
-Tha Mp3 Doctor
Nov 14, 2008 | Philips DVDR3576H DVD Recorder
DVD Recorder LVW5101. Unit records ok but will not play back material it has just recorded
At present, I assume I hard several defective Discs. I use DVD-RW and have had good results. I also think I am having problems with Erased Discs. I need to do more experimenting. Thank you for your respoonse. I will keep you response in caseof further problems.
Aug 11, 2008 | Lite On Televison & Video
Unable tp play discs on computor
Have you finalised the disc ? Go into the menu and where you format the disc there is an option to finalise. It should then play on your laptop. Hope that helps ;)
Jan 04, 2008 | Samsung VP-DC161 DVD Camcorder
Sony DCR-DVD 108 disc won't play or record
Movies shot DV Camcorder forms mpg files when down loaded in computor and can not be converted to a CD. Problmes comes in conversion of mpg files to AVI, WMV, AVSEQ or MPEG2 etc.
Oct 29, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
Finalizing Discs
The only reason that you have to finalize a DVD-R disc is so that you can play it back in an external DVD. Once finalized, you can no longer add motion video to that particular disc. Discs that are not finalized can still be played back when inserted in the DVD-camcorder.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Panasonic VDR-M53 DVD Camcorder Logo
270 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
