I need a Canon Starwriter 400
We have a Canon Starwriter 400, but the carriage won't move. Can someone fix it or does someone know where we can get a replacement?
  • 3,594 Answers
There is one on ebay current bid is .99.
DickyO
Posted on Feb 24, 2009
Canon StarWriter 30 no longer turns on
Check the power cord to be sure it is plugged in well (on both sides if it is removable from the unit). Try a different outlet if you haven't already.
Check the machine for a small reset button or hole and try that
Finally, these machines run about $60...here's a link (see below) I found for one with free shipping....not my machine...I just found this for you.
http://www.etsy.com/listing/157891342/free-shipping-canon-starwriter-30?utm_source=google&utm_medium=product_listing_promoted&utm_campaign=vintage_mid&gclid=CI6Rn4jog70CFZLm7AodSU0A9w
Mar 08, 2014 | Canon starwriter 30 - Starwriter 30...
When I try to print, I get a notification, error 5110, turn printer off and on and if problem persists, call service center. someone said to reinstall printer software, but I cannot find any on the...
This error is one of the most common issue with Canon printer. And as you mentioned, "If problem persists, call service center", I can recommend you do that. In fact canon gives another replacement for the printer having this error and if it isn't possible to get rid of it manually. Let me share my experience and how I used to fix this error.
First, turn off the printer, unplug the usb cable and power cord. Now, also turn off the computer (it needs to be restarted since the error is showing on the computer and will never go until you restart the system).
I hope you are not using longer usb cable other than the one that came with the printer. Sometimes long and defective cable cause this problem.
When you turn on the machine, open the lid (front panel door) and help move the cartridge carriage with your hand so that it'll move sideways. Sometimes when the carriage stuck, this happens.
If the above tips don't help, you need to call Canon and ask them your problem. If you are in the U.S. use this number to call Canon "1-800-OKCANON" or you can write using this form (Click here)
If you need for help, let me know.
Good luck.
Thanks for using FixYa.
Aug 17, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I need the reset code for cannon starwriter 350
Canon GENERIC "S" SERIES RESET CODE
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Oct 08, 2009 | Canon Office Equipment & Supplies
My canon starwriter will not read 3'' floppy discs...please help.
I cannot solve your problem but I have a Canon Starwriter 80, in great working order, for sale, if you are interested. Email me at wagtail@chartermi.net
Sep 08, 2009 | Ultimate Sound Office Equipment & Supplies
Canon MP850 error code 6A00 flashing lights. no
Hi
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon i80 service error 5100
Hi guys,
Service error 5100 indicates that carriage return (CR) operation is not performed successfully. After the printer turned on, printer initialize some operation include CR operation. This error happens when carriage part (carriage unit) has problem when move right and left in initialization process.
This may be caused by:
  • Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
  • Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
  • Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
To fix this problem you may try the following tips:
  • Check if any material present in carriage path; remove (clear) it
  • Check if film encoder is dirty; wipe slightly with moistened clothe.
  • At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Please don't forget to rate me.
Regards,
Source:
Inkjet Printer Forum
Dec 24, 2008 | Canon i80 InkJet Printer
Canon i80 error 5100
Hi antoinette,
Someone has ever asked this problem and I have post a solution for this. Here is my answer:
* Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
* Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
* Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
* Check if any material present in carriage path; remove (clear) it
* Check if film encoder is dirty; wipe slightly with moistened clothe.
* At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Best regards,
Source:
Dec 18, 2008 | Canon i80 InkJet Printer
Canon starwriter 400 won't print
Usually the problem is a plugged cartridge.
It is possible the ink cartridge is empty.
It would be best to buy another cartridge and try that first.
Dec 14, 2008 | Office Equipment & Supplies
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
151 people viewed this question
jasbo
jasbo
