Question about GE Nautilus 24" Built-in Dishwasher
Locked timer knob in GE Nautilus dishwasher
Locked timer knob in "plate heater" position just below "OFF"
  • 170 Answers
I ran into this problem earlierr today ....Check the float valve...it is a round looking device in the front (usually) of the DW...if this gets stuck it will (or may) get stuck in drain or in assist dry mode...push it up and down you should here a clicking noise. Take it out and see that there is no debris in it ...if so clean it ..and replace...then try the Dw.
I hopr this helped....good luck....thanks for rating my effort...The Fang.
Posted on Mar 28, 2009
My dishwasher is not running when you turn the knob it will open and close the detergent
The soap dispenser is openned mechanically by the movement of the knob by the timer. So even when it is unplugged the soap dispenser will open if you turn the knob. Try a different plug. Otherwise check the cord. Next you would check the power supply inside.
Feb 05, 2011 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
My ge nautilus kept stopping during wash and now will not start at all.
This is quite likely the timer or the cam. It can be replaced. Since they use a mechanical timer it can simply be off track. If you aren't afraid of disassembly I would take the timer panel apart and have a look. You may be able to fix it quite easily. Otherwise the timer is about $50. The cam is only $15.
Jan 09, 2010 | GE 25 in. Nautilus GSC3400J Free-standing...
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
I need to order a control cycle knob for my 2001 dishwasher
Try this site, if you live in a large enough center you may have a store in your area. It's a great resourse site, type in your model number, has exploded views of your machine.
http://www.reliableparts.ca/
Apr 18, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus detergent cap will not open
Sometimes these get gunked up and need to be coaxed....so take a butter knife...insert it in the edge of the dispenser tray...pry gently...all the while turning the timer control knob...it should pop open at one point if not try a little more pressure...and once open .clean thoroughly..if it persists you may have a timer or control panel issue...also use factory recommended soaps...
I hope this helps...Good Luck and Good day....thank you for rating my effort.....The Fang.
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher - The soap door is stuck partcially open
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
Jun 27, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
279 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
