Question about Directed OHD1040 Car DVD Player
Player will not shut off at all...
When I turn off the SUV pull the key open the door, the player is still running. Took it to be looked at and they said the unit holding a charge on its own...and that I need a new player!
  • 152 Answers
There are typicly two types of 12 + volt connections that could be made to this unit.
1. Constant = continouse 12+ volts
2. switched = Power is controled by the ignition switch.
There is a small internal battery inside that unit that is only used previde power to that units memory, and does not provide enough power to operate the player.
Its possable that the power supply needs to be changed to a switched circuit.
Hope this helps. Good luck...
Posted on Feb 24, 2009
Equinox radio
Possibly, the bundle that goes through the door also have speaker wires in them. Check there.
Nov 24, 2013 | Cars & Trucks
Door lock and will not open once you unlock it.
its more than likley the solinoid that controls the lock itseilf.
try removing the door lock fuse,
you should be able to use the lock manually untill you get a new solinoid,
good luck,Gary
Oct 24, 2013 | 2003 Chevrolet Silverado 1500
The DVD will not stop spinning. The door will not open either. When I took the cover of the players and plugged it in, the DVD just keeps spinning even when I hit STOP, OPEN, and turn the player OFF. ...
I've had this problem twice now.
The first time, I unplugged the unit for about a minute, plugged it back in and pressed the Open button. The disc was ejected and ran fine for about a week.
Then it happened again, but the unplugging didn't fix it this time.
Try this;
Unplug the unit and let it sit for a few mins to let the disc stop spinning. Then gently pull down on the DVD door. Look at the lower left side of the DVD tray and you should see a large slot. Shine a light into the slot and you will see a dime size white gear. I used a small flat head screwdriver to spin the gear to the right. After 2 small turns, the DVD tray opened enough so that I could pull it gently open. I took the DVD out, gently pushed the DVD tray back in and set the DVD player on my workbench to tinker with on a rainy day. Not sure what the root cause is, but I'll worry about that later!
Aug 14, 2009 | Samsung DVD-R135
DV2140 DVD player door will not open.
Most manual overrides involved pressing and holding either the eject button or the power button on the machine itself (not the remote). Try those first.
If that doesn't work reply with the following info:
Will your system turn on/off?
Are you able to play the disk that's in the drawer?
Jul 09, 2009 | GoVideo DV2140 DVD Player/VCR
Radio won't shut off chevyexpress van
check all of your fuses especially if the cd player was just installed and you made the wires touch
May 06, 2009 | 2003 Oldsmobile Alero
Dvd player
I took some screws from the sides off, and lifted up the top. I took the dvd out of it. It seems to be working good now.
Jan 26, 2009 | Philips GOGEAR SA6045 MP3 Player
My dvd says open door will not open
You probably need a new dvd belt it is 24.25 mm rectangular. or it could've slipped off. Take off cover and move white wheel with teeth very gently until dvd tray starts to open then you can gently pull on it only pull it half way out and look in center of where dvd would normally be. There you will see the bigger and smaller wheels that control dvd player. look around for the belt. Make sure power is off when you do all this.
Dec 23, 2008 | Sony SLV-D350P DVD Player/VCR
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
I have no idea
the cd player you are running is probably too much for the alternator that's in the car, especially if it won't start now... take the car in and have them check out the alternator... get this replaced if needed... if you can't do this, simply remove the cd player you installed and see if this fixes the problem... if so... take the cd player in to a certified pro and have them install it for you so you don't have to splice any bad wires and your car will continue to run.
hope this helps :)
May 17, 2008 | 1999 Dodge Neon
I turn on my cdn36.......
There are switches that detect the door opening and closing, those switches need to be cleaned or replaced. That is really all that will cause this type of problem.
Good luck,
Apr 13, 2007 | Nu Mark Numark Cdn36 Dual CD Player CD...
Directed OHD1040 Car DVD Player Logo
103 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
