Question about Ricoh Aficio 2022 All-In-One Laser Printer
Error message sc 172 on ricoh aficio color 2103
My machine is ricoh aficio color 2103. when i turn on the machine it gives an error message sc 172
You'll need a tech on site for this one, but it may be difficult to source parts if required for this old box. One of the following situations has occured:
• Poor connection of CCD
harness
• Dirty optics
• Defective lamp regulator
• Defective main scanner IPU board
• Defective CCD
Posted on Feb 24, 2009
Error sc 305 ricoh aficio sp 420dn ?
The SC 305 on a Ricoh SP 420DN is related to a AC bias charge error for the magenta color.
The machine sence there is a charge current that is less then
200 ?A is detected.
There are four reasons why this may happen.
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power board 1
Follow this procedure, and see if that does the job.
1. Check the connectors.
2. Replace the PCU for magenta.
3. Replace the drum positioning plate.
4. Replace the high voltage power board 1.
Let me know if you need more info, part numbers and stuff like that.
Jul 09, 2017 | Ricoh Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Erreur 172 aficio 3506 COLOR
need to clean the optics for sc-172
Apr 06, 2014 | Ricoh Aficio 1232C Color Copier
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
Ricoh Aficio 2022 All-In-One Laser Printer Logo
344 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
