Question about Canon Rebel XT / EOS 350D Digital Camera
Lost previous pics after checking used memory on CF card
I went to "Format" to see how much memory was used on the CF card on my canon rebel xti and when I said OK it reformatted. Have I lost all previous pictures?
Have you used the card since if not there is a program you can download that can help recover the data
Posted on Feb 23, 2009
Cf card error
The file system on your CT memory card can be corrupted. It only takes one second, when you not watch the access light on the back of the camera, when you pull out the memory card. If the card does not contain any pictures, just try to format it. If it won't work in the camera, try to format it in an external card reader connected to a computer with an older operating system then Vista. Give it a format FAT 12 or 16 for the smaller CF cards (less than 2 GB) and FAT32 for the bigger ones.
If this works, don't forget to let the camera do a format to, just to make sure the card can be used by your camera.
Feb 01, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
My canon rebel xti will not power up with a cf memory card in place. I tried two different cards. With no card in place it works fine.
check for bent CF pins. Also remove the back cover and make sure the bottom right rear circuit has not come loose and is not shorting out the board
Oct 13, 2013 | Canon Digital Rebel / EOS-300D Digital...
I have lost my camera book and need help .when I try to print pics at Walgreens computer will not load says no photos available.but I can take pics fine and look at them on cf card in camera b
You may download the manual and more from here.
Are you possibly shooting pictures in RAW format? Photo kiosks such as those at Walgreens won't recognize Canon RAW photos, only JPEGs. Check the camera's image quality settings, as described beginning on page 60 of the manual.
Nov 14, 2012 | Canon EOS Digital Rebel XTI Digital Camera
I took the CF card out of my Rebel XTi EOS camera to look at the pictures on my computer. When I put the CF card back in the camera I am getting the message "There is a problem with the CF card. ...
This is an old posting but I'd like to comment that once the memory card is used in a computer it won't read in the camera again until you format the memory card. Make sure you have all your pictures on the computer before formatting the memory card. A memory card must be formatted in the camera it is going to be used in.
Jan 01, 2011 | Canon EOS Rebel XSi Digital Camera
I have a Cannon EOS Digital Rebel Xti. When I try taking a picture, I keep getting an error message indicating there is a problem with the CF Card. I have replaced the card several time but keep getting...
What you require is to format the Compact Flash Card. The CF card should be formatted when new and after every download. Format the card in the camera it is going to be used it. Constantly deleting pictures on the memory card will cause major corruptions and total failure. Formatting cleans the memory and allows the camera to communicate properly with the CF Card.
I going to give you several diagrams on where to go in your camera to format. these diagrams are screen shots right from your manual.
Dec 29, 2010 | Canon Rebel XT / EOS 350D Digital Camera
EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens: went on a trip to europe. took lots of pics and we...
1. There are hundreds and hundreds of programs that can restore lost files from a formatted drive... just google it
2. You cannot use a usb cable to transfer files (or at least not on my computer) with this camera, you have to take the card out of the camera and directly plug it into your computer
Hope I helped
May 18, 2010 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon rebel xti digital camera mem. card will not lock into place
It seems that the CF reader mechanical assembly part has loose or out of place an internal part.
It may be caused by excessive force in pushing/pulling a CF memory card, or due to a manufacturing issueof the camera.
The solution is to open the camera, and check what is causing the problem and fix it.
If it's under warranty, I do recommend you to return it. If not, then you will need to pay for its repair, or do it yourself if you have experience, skills and patience in fixing electronic devices.
Such repair will require some philips screwdrivers, a soldering iron, soldering wire, and a st of tweezers.
There are in internet some guides to open and disassembly Canon XT 350D or Rebel 300d cameras. The disassembly process with the XTi 400D is very similar. You can Google fr such guidelines.
Best regards,
May 24, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Why does the word, ''busy'' pop up on the canon rebel xti?
This is the camera writing to the CF memory card. Perhaps your card is a lttle slow, so you will see the message. I use the Sandisk Ultra II CF, labelled as 15Mb/sec and it is very very fast indeed - I don't have any lag with my XTi. Try a different CF, if it is fast enough, the message will go away. Ensure you format the card on the camera too.
Apr 13, 2009 | Canon EOS Digital Rebel XTI Digital Camera
New canon eos digital rebel xti
There have been several reports of CF cards that work with all cameras, except the Rebel XTi. It depends on the actual manufacturer of the card. Canon made a change mid-production that affected the data saving. Try another brand of card & you should not have that problem any more.
Jun 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Image upload
??? These cameras take standard CF cards (and store images in standard JGP format) that can be 'read' directly by PC's with a multi-media card slot.
If your PC does not have a card slot, you can buy a USB CF Card Reader/Writer for a few dollars ..
PS always reformat the CF cards in the Camera not the PC ..
Apr 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
