Question about Sony Handycam CCD-TRV318 Camcorder
Doesn't play or record
On screen has flashing c:31:23 and sign like arrow facing up, flashing at the same time.
    President:
  • 2,992 Answers
I haven't seen one of these in a while so I don't remember for certain what the error actually means. I think it has to do with a cover sense switch that doesn't think the loading door is closed, but I may be wrong. A Google search turned up a lot of sites and posts that say to give the side of the camera a whack and try it again. Apparently there's some mechanical issue and the slapping technique gets it going again, at least for a while.
It's worth a shot, anyway. I'll look through my Sony stuff if I can find my files and see if I can come up with anything more. In the meantime, if this has helped at all, please take a moment to rate this solution. And thanks for asking here!
Posted on Feb 23, 2009
Closed the loading door hard,slammed it shut ,problem went away
instantly many thanks.
rick
Posted on Jul 26, 2009
I got a new machine, when I transfer from VHS to DVD-R it records, but will only play on the machine I recorded on, it doesn't load on other DVD players, why is that?
You need to FINALIZE the DVD-R you recorded in that unit for it to be playable on other DVD players. This function should be part of the on-screen menu for your unit. (in Panasonic DVD recorders, it's under DVD MANAGEMENT in the FUNCTIONS menu).
If the disc you recorded is already loaded, but stopped, press SETUP on your remote - an on screen menu should appear.
Using the UP/DOWN arrow keys, select DVD MENU and press ENTER. Use the UP/DOWN arrow keys again to select FINALIZE and press ENTER.
A message box will popup 'Finalize disc?' use the UP/DOWN arrow keys to select YES then press ENTER. Finalizing should start and may take a while to complete.
Once complete, the disc is now playable on other DVD players. (from page 32 of the owners manual with the heading 'PLAYING THE DISCS IN OTHER DVD PLAYERS')
Feb 10, 2013 | Toshiba DVR620 DVD Recorder/VCR
How do i change the recorded message on my voicemail. i cannot find the answer to this question anywhere in my instruction manual. thanks.
Answering system settings
Record your own announcement
Using the telephone base:
Press •/REC while the telephone base is not in use.
Press /CID or /DIR to select Announcement, then press the SELECT softkey.
Press /CID or /DIR to select Mailbox 1 or Mailbox 2, then press the SELECT softkey. The corresponding icon, 1 or 2, flashes on the screen.
The telephone base announces, "Record after the tone. Press 5 when you are done." After the tone, speak towards MIC (microphone) of the telephone base. Press 5 or the STOP softkey when finished recording.
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at any time.
-OR-
Press the MENU softkey when the telephone base is not in use.
Press the SELECT softkey to select Answering sys.
Press (down arrow)CID or (up arrow)DIR to select Mailbox 1 or Mailbox 2, then press the SELECT softkey. The corresponding icon, 1 or 2, flashes on the screen.
Press CID or DIR to select Ans sys setup, then press the SELECT softkey.
Press CID or DIR to select Announcement, then press the SELECT softkey.
The telephone base announces, "To play, press 2. To record, press 7." Press 7 to record and the screen shows Recording announcement ..., or press CANCEL to exit to the previous menu.
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at any time; 2 to replay the recorded announcement; or 7 to record again if desired.
Press CANCEL to exit to the previous menu.
Feb 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Deleting recordings off sony icd-mx20
Display the folder o message in the folder that you want to erase.
Press Menu and select Erase by using up arrow down arrow and then press play stop button, the cursor moves to erase menu.
Press up arrow down arrows to select erases all the messages or message in a folder.
Press up or down arrow to confirm say yes and press play
Press stop to exit.
Mar 31, 2009 | Sony ICD-MX20 Digital Voice Recorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Timed recordings for VCR
You can get the manual here. The bad thing is you need to sign up with them but it is free. You will see the manual on the page when you open the link.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck
Dec 29, 2008 | Hitachi DV-PF2U DVD Player/VCR
C:31:22 FLASHING WITH THE YELLOW EJEXT ARROW FLASHING
I can play or record and it gives me the eject sign. At times it gives me the message 'cleaning casette'
Jun 13, 2008 | Sony Handycam DCR-TRV250E Digital...
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cannot record
it is a reel sensor problem...try to adjust the contact of the sensor at the main board sometimes it is a poor connection or poor solder...
Aug 26, 2007 | Sony Handycam DCR-PC105 Mini DV Digital...
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Sony Handycam CCD-TRV318 Camcorder Logo
370 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
