Question about HP LaserJet P3005n Printer
Printer prints poor quality copies with one black smudged stripe down left side of paper and paper gets wrinkled before coming out. I've just replaced ink cartridge and done cleaning of cartridge. I've experimented with high and low fusion settings and they don't seem to make a difference.
  • HP Master
  • 4,806 Answers
Hi there.
The whole of the printer needs to be cleaned. Turn off the printer, Unplug the printer from the surge suppressor, Remove the internal paper trays, Remove the toner cartridge and place it on a piece of scrap paper, Clean inside the toner cavity with a dry, lint-free cloth and brush (if a brush is supplied with the printer), Clean the printer mirror gently with the brush. Don't touch the mirror if a brush isn't provided, Wipe away dust and spilled toner. Remove paper fragments, Clean the rollers, but don't touch the sponge roller, Replace the toner cartridge and put it all back together again.
Then try printing again and i think your problem will be resolved
Good luck and thanks for using Fixya!!
Posted on Feb 24, 2009
    Scholar:
  • 165 Answers
Its not at all the problem of cartridges.its the problem of laser beam in your printer that is having dust on it .so that laser has to be cleaned to make it proper.get the printer serviced.
to check out how the laser beam looks
http://farm4.static.flickr.com/3104/2550956836_f1135cff1b.jpg
click the link above.
please do rate the solution.
    Top Expert:
  • HP Master
  • 77,169 Answers
Try doing a print head clean a few times, but this sounds like a defective or overfilled cart problem.
Posted on Feb 23, 2009
HP 1600 prints with left side smudging
If you are ask printer paper Quality then first you check it ink label and then you check paper quality because both are depend which types of quality you are used. If one in dull then printer quality also dull. I share a print quality related link please read and follow instruction.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01691481
Thanks,
HP Printer Support
Apr 04, 2014 | HP LaserJet 1600 Printer
I have a Canon Imagerunner 1023if and have black smudges along the left edge of paper, both copies and printed directly from computer.
this is possibly a problem in the fuseing part of your machine, where the paper heats up at the back, the fuser roller could be worn out. and your toner could be sticking to it.
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
I have black smudgy lines going down the left hand side of my printed copies. What do I do?
1. Check the toner level, when it's low the quality of the prints becomes poor.
2. If toner level is good, clean out the printer inside. The best way is to buy an air compressed can, get the printer in an open space and blow any toner from the inside of the printer. Give it a good clean as there might be residual toner inside that make the poor quality.
Nov 29, 2010 | HP LaserJet P2015n Printer
Black stripe running down left side of paper when
Open the top of the fax where your documents go in. There will be a thin **** of glass where the document is read. On the end that reads "dirty" is a smudge or some white-out that needs to be cleaned. You may have to clean it with some cloth wrapped on a flat tool. Do not scrap or scratch anything, just clean enough to get the dirt off. Then make a test copy.
Apr 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Black mark on printed copies
Remove the black drum and see if see the line on the drum that you see on the paper---if it is replace the drum unit.. Good Luck
Aug 26, 2008 | Ricoh CL4000DN Laser Printer
Black strip Mark on paper after print
Ramana is the black stripe just showing up on copies or faxes or does the stripe occur when you are printing from your computer. If the stripe only occurs when copying or faxing then more than likely the scanner glass is dirty. White out liquid on the scanner glass is a common.If it happens when printing fromyour pc, the problem will be in the toner cartridge or the fusing assembly.
Change the cartridge first to see if it goes away. Check the scanner glass, especially the small glass strip on the left side of the scanner or the right side where you place the original paper. These areas should be completely clear and clean of any scratches or smudges.
Last is the fusing assembly. If you tried everything else and theline continues to bother you, the fusing assembly sleve is probably torn. This would have to be replaced. The part number is RM1-0865-040CN.
Jun 23, 2008 | HP LaserJet 3030 All-In-One Printer
Print poor copy quality
Fuser pressure (2 green levers on fusing section) may be set to envelope position.
Mar 04, 2008 | Konica Minolta bizhub C250 All-In-One...
HP LaserJet P3005n Printer Logo
Seeker5211
Seeker5211
