Question about Plumbing
Faucet running in off position
I have a problem that maybe you can help me with. I have a single handle faucet that I installed last night. It's it the kind where the sprayer and the faucet are the same head with a switch on the back of the head that switches between spayer and regular faucet. After installing, I turned on the cold water at the shut off valve and the cold water comes out of the faucet at full pressure even when the handle is in the off position. The hot water works fine. It comes on when in the on postion and goes off when in the off position. The cold water will just run, regardless of the position of the handle-off or on. I had to turn it off at the shut off valve until I can figure out what the problem is. Any suggestion
  • 547 Answers
The fixture is set up so off is full to right as you go to the left the cycle is cold then hot if you don't understand turn tap all the way to right and turn on main if you need more help please post comment thank you for useing fixya please rate me
Posted on Feb 23, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    The handle on my rohl kitchen faucet won't hold its position, how do you adjust or tighten the handle?
    under the counter there is a nut that needs tightened . usually need a swivel head faucet wrench to get them tight .
    Feb 14, 2015 | Rohl A3608LMPN Single Lever Country...
    Installed new kitchen fauce. no water running though faucet but is running though sprayer. what could be the problem?
    Sounds like the diverter that transfer water from faucet to sprayer is bad or stuck. Try turning water off and removing handle and remove spout to acess the diverter is near the base of the body of the faucet. Below is a link with a exploded view that will show you a parts breakdown hope this will help.
    http://www.moen.com/shared/pdf/ca87530pt.pdf
    Jun 26, 2011 | Moen 87530 Touch Control Single Handle...
    Getting hot water when shower valve is first opened.
    If I understand correctly, you have single handled shower faucet.
    Normally there is a wait for hot water to arrive at faucet.
    But now hot water is already at shower faucet.
    Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
    This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
    How it happens:
    For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
    So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
    To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
    This condition may also signal there is a water leak.
    The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
    Replace faucet or have plumber repair problem.
    Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
    I instslled new delta single shower faucet ,the water is running for 5 to 10 sec even if the shower handle is in off position
    Sounds like someone did not remove the plastic valve assembly before soldering the valve body to the copper piping.
    That or the valve body needs cleaned out. It is common for debris to get knocked lose when doing installations on old plumbing.
    Jan 29, 2011 | Delta & Single Handle Shower Faucet
    Single handle shower/bath faucet is dripping. Want
    I can fix this.
    What is the last thing you did before this problem started?
    Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
    I HAVE A SINGLE HANDLE HIGH NECK BLANKO KITCHEN FAUCET THAT IS RESTRICTING THE FLOW OF WATER WHEN TURNED IN THE HOT POSITION. THE WATER IS FLOWING FINE IN THE COLD POSITION BUT WHEN TURNED TO HOT...
    If water come out the faucet hot line,check if is clogged.For this job you need to disassemble the faucet.
    Here is a good PDF source to do it.
    If you need more help come back.Post / thumbs / testimonial are welcome!
    Nov 12, 2010 | Blanco Classic Single Handle Faucet with...
    I have an older delta faucet. Sprayer does not work well.
    i believe the faucet shaft,..they usually are on delta models i've worked on,........your best to get a full rebuild kit for this and do the whole thing when you've got it down,.....good luck, cracklin joe
    Jan 10, 2010 | Delta Faucet #RP320 Divert Assembly
    Difficulty shutting off faucet after installation of cartridge
    sounds to me like you did not engage handle properly the moen has like a half moon in handle that has to go on just right and can be a little tricky if it went on easy its not on right
    May 03, 2009 | Plumbing
    Plumbing Logo
    223 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
