Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore model #50562992 freezerand refrigerator stop working
Kenmore model 50562992.the freezer stop working and the refrigerator. What I need to check.
  • 31 Answers
SOURCE: Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
lojacksdad
  • 121 Answers
SOURCE: Fridge quit working but freezer works
check to see if the back wall of the fridge is full of ice
if so that is an automatic defrost problem or check to see if your frezzer fan is blowing
Posted on Apr 17, 2009
SOURCE: kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Posted on Dec 22, 2009
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Kenmore Top Freezer Refrigerator
Kenmore side by side refrigerator 58642891
depends on the AGE of the one you have needing repairs . FIXYA can not determine what you need to do .
Nov 14, 2017 | Kenmore 56563 Side by Side Refrigerator
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
Jan 11, 2010 | Maytag Refrigerators
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer stopped freezing
It is possible that the fanmotor in the freezer compartment is faulty which would cause a freeze up and prevent the air from circulating.
Mar 05, 2009 | Kenmore 44103 Side by Side Refrigerator
Freezer not defrosting
Hello pumpguy2
Welcome
You said, you have a Kenmore bottom Freezer Model 596.73503201. It works fine but the freezer has stopped defrosting. Any suggestions?
It is supposed to be auto or self defrosting.
What do you mean you are getting ice forming in the freezer?
Waiting for your response and more detailed explanation.
Huuum
Oct 01, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore side by side not getting cold
check the condenser motor at back of unit if is not running it will get hot in the middle section and it wil not cool properly
Aug 06, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
604 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
