Question about Ricoh Aficio CL2000N Laser Printer
Won't turn on....
My printer has an error: SC441, power on/off. Also, I have a color regist. permanent error.....
any help is greatly appreciated....
Have you recently replaced the colour PCU? It may not be seated properly, otherwise there is likely a problem with it, and it's not turning (ie: a broken gear). It could also be the PCU drive motor, or control board. Sounds like you may need a tech to get to the root cause unless you have a spare PCU to try?? This also explains the colour registration problem.
Posted on Feb 24, 2009
Sc 441 error massege
The SC441 error means one or more of the developer units (PCU) is not rotating. You have to take the PCU out to see which color isn't rotating. One of the doctor (cleaning) blades might be flipped, usually caused by lack of toner in the PCU.
Basically, if you just open up the printer, latches and everything, and just make sure the parts are all able to move freely by giving them a bit of a test with your hand, then close the printer up turn it off then back on and it should be working.
Jan 04, 2013 | Ricoh Aficio CL3500N Laser Printer
My RICOH AFICIO CL3000 give me an error message SC441, what to do ?
Did you just replace your color PCUs (photoconductor units)? If so, one of the new units may be defective. Try reinstalling the old units to see if the problem goes away (after resetting the machine). If it does, you can replace the PCUs one by one to see which one is bad.
If you still get the sc441 even with the old PCUs (or if you don't have them anymore) install a set of new PCUs and that should fix the problem. On the off chance the problem doesn't go away even with new PCUs, contact your local service company because you may have a bad circuit board, motor, or gear.
Nov 15, 2010 | Ricoh Aficio CL3000 Laser Printer
Ricoh CL3000 error sc441
sc441 is a drum motor error. It could be caused by anything from a faulty circuit board to a bad motor, but the most likely fix (and the easiest) is to replace the color PCUs (photoconductor units) which I believe all come as one set.
Turn the machine off and unplug it from the wall, then install the new PCUs, plug it back in and turn it on. There's a good chance your printer will work fine. If the sc441 error comes back, you should contact your local service company and have them take a look at it, because the problem is either electrical or mechanical.
Hope that helps!
Nov 09, 2010 | Ricoh Aficio CL3000 Laser Printer
Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Jan 21, 2010 | Office Equipment & Supplies
Error message on a Ricoh 2000 SC441. What does
SC441 mean scanner or laser unite problem.Open it and clean laser mirror,or clean scanner door sensor.
Dec 09, 2009 | Ricoh Aficio CL2000N Laser Printer
On power up displays SC441
SC441 indicates Development Motor Lock / Drum Peripheral Component Motor Lock.the code indicated one of four things. It could be either the Color PCU, the gears that drive the PCU, the motor or control board. The easiest of course is to replace the color PCU, but that runs around $300, but the other parts required a bit of disassembly to examine.
Oct 21, 2009 | Ricoh CL3500N Laser Printer
Green and red light permanantly on.
Green and red light on : ink out error / chip doesn't recognized. If u use SSC, and said "Coomuniaction error", it's normal. Replace ink tank, or use CISS chip.
Jun 11, 2009 | Epson Stylus 680 InkJet Color Printer
Ricoh 3500N - Photoconductor Problems
I thought the SC441 error was a "Drum Peripheral Component Motor Lock", have you tried cleaning in and around the drum. Maybe the motor is going bad or there's some kind of obstruction.
May 22, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio 3500
sc441 error means one or more of the developer unit(PCU) isnt rotating. you have to take the PCU out to see which color isnt rotating. there maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
May 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
197 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
