TV power on relay does not work. This is the second time this has happened.
  • 1 more comment
  • etc_revlimit Feb 23, 2009
    This unit is a 1993 Toshiba 32" analog television. It is not a projection tv.
  • etc_revlimit Feb 25, 2009
    This TV is a model CF3266A. It needs a STR55041T regulator IC. Where can I get one?
    The model # is CF3266A . It needs a regulator IC STR55041T.
  • 479 Answers
If the relay is not working then only solution is to replace it.
Posted on Feb 23, 2009
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
What is your model ?
  • 1 more comment
  • SAM ANDERSON Feb 24, 2009
    There is a short
    somewhere in the set . If you have a volt meter you can check the fuses to see which one is open. The fuse will be somewhat rectangular in shape and can be found around power supply board .
    Hope this helps .
    If you need further help feel free to ask .
  • SAM ANDERSON Feb 25, 2009
    You can get the price quote for the part from the link below
    Order STR55041T from this link
    Or
    try this alternate link for buying the IC
    Order STR55041T from alternate link
    Hope this helps .
    In the first link enter the part number and quantity for getting the quote .
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Avr-f100 surround left and centre working intermittently can anyone help.
The same happens with my POA-F100, but only the center channel is affected (apparently the most important for movie/tv).
Seems to be a malfunction of the speaker relay (you can hear it clicking some seconds after power on). In my case a (sometimes pretty rude) hit on the side of the compartment with the flat hand helps, so the contact just mechanically hangs.
If I find the time I will open up the compartment to see if I can get a fitting spare part relay and solder it in (so I don't have to beat my Denon Setup any more ;-)
Jan 03, 2011 | Denon Audio Players & Recorders
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Toshiba Color TV Relay clicks slowly. TV does not come ON.
Electrolitic Capasitors in the power supply going or being bad will cause this. At some point a low value resister also will start to run hot or burn up. I believe it it a 16v 1500 uf cap near the relay. I would also replace any 10uf 160v caps in the powersupply too.
Hope this Helps,
Skyassoc
Jun 17, 2009 | Televison & Video
T V Goes on to Green Light Yet Box Stays On Red
I have an AV3000E that developed this symptom following a 5 second power cut.
I downloaded the manul, suspecting a power supply problem. The way the AV3000E works is to have a 5 volt power supply running all the time, this powers the main processor. The main processor then energises a relay (S901) by applying 5V DC between relay pins 3 and 4. The relay contacts switch rectified mains power to the main switching regulator. The replay was being energised but appeared not to be switching. While the AV3000E was connected to the mains, I carefully I connected a short between relay contacts (1 and 2) while the processor was trying to energise the relay coil. The TV burst into life. I removed the short and the TV continued to operate normally and has done so ever since. I cannot entirely rationalise why this has worked as this should not have fixed the relay, what may have happened is that the short power cut may have resulted on the some corruption of the processor non-volatile memory, and that the incorrect operation of the main relay caused the processor to reset it's internal memory.
BE WARNED, WHAT I DID WAS EXTREEMLY DANGEROUS AS THE RELAY CONTACTS I SHORTED ARE CONNECTED TO THE MAINS SUPLY - YOU ARE LIKELY TO KILL YOURSELF IF YOU DO NOT KNOW WHAT YOU ARE DOING - PLUS I TOOK THIS ROUTE AFTER ELIMINATING THE OTHER OBVIOUS PROBLEMS LIKE FAILED FUSES.
May 27, 2009 | Hitachi 42PD3000 42 in. Plasma Television
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Samsung TXG2547 25"inches TV problem
you have damage your tv micro chip, regulator ,or horizontal output with static current when you plug out your tv from th plug,what is clicking is the relay trying to power up your tyv but due too the damage it cannot power have a tech repair your tv good luck
Oct 26, 2008 | Samsung TXG2547 25" TV
Sanyo DP32746 Power Supply
Yes replace the power section of the tv.
Jul 13, 2008 | Sanyo DP32746 32 in. LCD Television
Sony Big Screen TV Not Powering On
This looks like a problem with the High Voltage or switching power supply section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, and check the voltage output of the switching power supply. What may have happened is a component may have shorted out causing an over-current condition with is triggering the shutdown circuit (These are the relays you are hearing). I would check the Horizontal Output transistor, and the components in that section of the TV.
In addition check the voltage test points on the HV / Horizontal and switching power supply board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I hope this helps,
Thank you,
Shuttle83
Aug 15, 2007 | Sony KP-46WT500 46" Rear Projection...
A32B43W Power Problem
The relay is part of the overcurrent circuit. This denotes a problem in the HV power supply. Try to resolder the relay just in case the it has a cold solder joint. If this does not help get a schematic and a multimeter and check to see if the voltages around the power supply seciton of in order. If you do not have a background in electronics please take the set to a TV repair shop.
Jul 02, 2007 | RCA F32450 32" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
