Question about Lenovo ThinkPad R51e Notebook
BSOD says boot partition is full, when it isn't
Computer boots up to blue screen of Death. message 0x00000073 with a descriptor of 0xC000017D, suggesting the system partition is full. It isn't. It's a Dell Vostro 1500 series.
  • Anonymous Feb 23, 2009
    I've tired booting into safe mode and I've run check disk. I've also ran a Mem test on the thing. Still it comes up with the same error. It'll boot up into the Dell media boot Splash screen then as soon as it tries to go into windows it Gives the same BSOD with the same message.
  • 477 Answers
Hello
try to boot in safe mode.(press F8 after bios bootup)
if that doesent work run chkdsk.(boot from windows cd and choose R(repair mode) go to the console and write chkdsk /R let that run and try to restart when its done.
Posted on Feb 23, 2009
Blue screen problem on my HP smart touch iq 770 list of solutions
A Blue Screen of Death (BSOD), also called a STOP Error, will appear when an issue is so serious that Windows must stop completely.
  1. The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did.
    Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD.
    Undo the change you made and test again for the STOP Error. Depending on what change you made, some solutions might include:
  2. Verify that a minimum amount of free space is available on your Windows partition. Blue Screens of Death and other serious issues, like data corruption, can occur if there's not enough free space on your primary partition used for the Windows operating system.
    Note: Microsoft recommends that you maintain at least 100MB of free space but I regularly see problems with free space that low. I usually advise Windows users to keep at least 15% of a drive's capacity free at all times.
  3. Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
    Important: Make sure your virus scanning software is completely up to date and that it's configured to scan the MBR and boot sector.
  4. Apply all available Windows service packs and other updates. Microsoft regularly releases patches and service packs for their operating systems that may contain fixes for the cause of your BSOD.
  5. Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
  6. Check the System and Application logs in Event Viewer (7/Vista ' XP) for errors or warnings that might provide more clues on the cause of the BSOD.
  7. Return hardware settings to default in Device Manager. Unless you have a specific reason to do so, the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
  8. Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
    Note: If you've made several customizations to your BIOS settings and don't wish to load the default ones then at least try returning clock speed, voltage settings, and BIOS memory options to their default settings and see if that fixes the STOP error.
  9. Make sure all internal cables, cards, and other components are installed and seated properly. Hardware that's not firmly in place can cause a Blue Screen of Death so try reseating the following and then test for the STOP message again:
Aug 07, 2012 | Computers & Internet
Windows Vista BSOD
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 20, 2010 | Microsoft Windows Vista Home Premium with...
BLUE SCREEN
Then press any key.
Then type "y"
Jun 06, 2010 | Dell Dimension E520 PC Desktop
My Acer netbook will not boot all the way. The screen showing that Windows XP is starting shows up, but then it stops at the screen that asks me whether I want to go into safe mode. I tried pressing F8 and...
Hi, STOP Error 0x00000073: CONFIG_LIST_FAILED STOP error 0x73 means that one of the top-level registry keys, also known as core system hives, cannot be linked in the registry tree. STOP code 0x00000073 may also display "CONFIG_LIST_FAILED" on the same STOP message.
This can be either SAM, SECURITY, SOFTWARE or DEFAULT. One common reason for this to happen is if you are out of disk space on the system drive (in which case param 2 is 0xC000017D - STATUS_NO_LOG_SPACE)
This is a serious situation. What has happened to the PC? Was there a power failure? Sudden restart? I cannot say exactly that this is the problem. We have to analyze further.
Here are some steps and information to help you.
First of all make sure you have ENOUGH DISK SPACE in your SYSTEM PARTITION (Volume). STATUS_NO_LOG_SPACE means that logs and hive enumeration is not possible due to lack of the space. System drives has page files on it as well so First thing you have to do is to save some SPACE. If you have Windows DVD (or CDs - use CD1) just insert it and boot from CD/DVD. Go to Recovery Mode (Key is R). In the recovery mode Type DIR. If you receive an Error you have to type chkdsk PartitionName: /f /r As an example if your system drive is C that would be chkdsk C: /f /r ( Spaces between C and /, /f and /r ) Then the disk will be checked for bad sectors. Partition table will be fixed to normal.
If you do not receive an error and if you could see the files: Delete some files using DELETE command. (Use with caution - Try delete ? or delete /? for a list of OPTIONS). Create some space (If you use Vista make sure you have at least 1GB Empty Space. A calculation. You have to have at least 1GB + Space for the Page File. Page file uses 1.5 x your RAM Size GB space.). Then Boot the machine and check. That should work.
This post has two parts since its too long.
Jun 02, 2010 | Acer Aspire One PC Notebook
Need to boot in restore mode. loaded a driver and its know going to the blue screen
Then press any key.
Then type "y"
Mar 13, 2010 | Computers & Internet
My Dell 1525 has a blue screen when switching on, says config_list_failed, I've switched it off & back on but just says the same, Technical information at the bottom says ***stop: 0x00000073 &...
from these errors, the hard drive is full and the system is out of virtual memory which is gotten from the pagesys, you need to get a new drive,, a blue screen is crash if you have a windows OS
Mar 09, 2010 | Dell Inspiron 1525 Notebook
Blue screen of death presario v2000
Then press any key.
Then type "y"
Feb 11, 2010 | HP Compaq Presario V2000 Notebook
I am using G60 T HP LAPTOP. NOW I AM UNABLE TO GET THE DESKTOP IN MY LAPTOP WHEREAS IT SHOWS TOTAL BLUE SCREEN
Try repeatedly pressing F8 whilst it is booting and using the safe mode option.
If it boots ok then un-install any recent software changes and try to re-boot normally again.
bsod (blue screen of death) can be cause by many things but there is usually some form of error message either just before or during a bsod.
That complete message would be most useful in diagnosing any further issues you may have.
Aug 18, 2009 | HP G60t with Intel- R Core- TM2 Duo...
Blue Screen on boot 0x00000073 with code 0xC000017D saying system Partition is full, but I know it isn't.
try to run checkdisk. (boot from windows CD and choose repair mode. write "chkdsk /R" and restart your computer when done.
Feb 23, 2009 | Dell Vostro 1500 Notebook
Lenovo ThinkPad R51e Notebook Logo
132 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
