Question about Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive
Maxtor One Touch III 350GB Ext. HDD does not show up on the PC
I've intalled this HDD to my Vista machine and my XP machine but neither of them can read the drive and produce a drive letter. It shows up in Device Manager on both machines, but no drive letter on either. Any ideas. This is a new drive...but I've had it a long time...NIB. Thanks,
Mel Canon
  • 1 more comment
  • melcanon Feb 23, 2009
    This is an external drive and I don't see any jumpers on it. How do you check the jumper settings then?
    Any other suggestions?
    The drive should be clean, it's never been used.
    Genius:
  • 1,550 Answers
  • Right click on My Computer.
  • Choose Manage (This will open the Computer Management window).
  • Go to the Storage category and select Disk Management
  • Right click the new drive (usually listed as Hard Disk 1) and "initialize"
  • You now have the option to partition and format the drive.
The default settings of Primary Partition and NTFS- Quick Format are recommended for new users.
Source:cnets.com
Posted on Feb 23, 2009
  • SAM ANDERSON Feb 23, 2009
    Also you can go to computer management through start ->control panel ->administrative tools ->computer management .
    Hope this helps .
  • 10,594 Answers
If its new external drive then please format it or run add hardware wizard in control panel.
    President:
  • 2,653 Answers
Mel,
Do you have any important files on the drive that aren't located anywhere else on your computer?
If that's the case this problem can be addressed very easily. Let me know and we'll go from there.
  • RescueTechLA
    RescueTechLA Feb 23, 2009
    It's NOT a jumper issue.
  • RescueTechLA
    Use this guide here to enter the Windows Disk Management console:
    http://www.theeldergeek.com/disk_managem...
    Once you're in it will either prompt you to initialise the external disk, if not just right-click the appropriate disk and initialise or re-formate from there. That will take care of your problem.
    Brigadier General:
  • 3,614 Answers
Check first the jumper setting for the drive.
  • 1 more comment
  • micromaster
    micromaster Feb 23, 2009
    Setting the order of the hard disk drive (Master, Slave)
    Jumper Location
    There are three cases of the installing jumper(shunt) if the jumper is located in the middle of connectors as above.
    They are Lower 32GB, Upper 32GB and With capacity limitation in upper 32GB.
    master
    slave
  • micromaster
    did not immediately see it was a external drive.
    ok. first thing you have to do is.
    try changing the data cable, better to test it on a different usb port or into a different pc.
  • micromaster
    i know it was not a jumper issue then, some clarification has been done, and i will wait after my advise has done.
Hi - I have a Maxtor One Touch III, 500GB drive (3-4 years old) that has backed up my last 3 computers running Windows XP. I'm now trying to connect it to my new laptop running Windows 7, when I run the...
Hi , it seems the 'error code that you are recieving, is due to a 'connection in the {USB}.
Try "Updating the Driver / Software!"
"Go to this "Website!"
Fill-in necessary information.
ie: Model #, Brand, and or Operating System...
"Select the [Drivers] you need from the "List."
View: OneTouch III EMC Vista Update:
View: OneTouch III USB
Read below:
---> "Updates software to run in Windows Vista/XP/2000"
"Download the Drivers!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-downloads&vgnextoid=35c6069f356d3110VgnVCM100000f5ee0a0aRCRD
Mar 15, 2011 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor one touch iii unable to read drive; the external hard drive previously worked and now it doesn't read the drive
please remove the raw drive from the casing
it may be a sata drive of maxtor please power it up directly to your pc with a sata power and sata cable
the drive will get recognised .
if it gets recognised it means the interphase between the disk and the ext casing has been damaged
if you fail , the disk has lost its firm ware or rom chip rom bin file.
both can be flashed and recover the drive
BEcaerful you can break the plastic casing while removing the raw drive as it had been machine dyed and fixed and you may not find any screw s outside
datarecoveryfactory
Sep 04, 2009 | Maxtor OneTouch III FireWire 400 (F01G500)...
Onetouch III mini windows XP drivers
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-downloads&vgnextoid=35c6069f356d3110VgnVCM100000f5ee0a0aRCRD here is some software for that
Jul 10, 2009 | Maxtor 60GB ONETOUCH III MINI-EXT 5400RPM...
All of a sudden my maxtor one touch III turbo does not show up on my pc--tried on another pc-not seen--then tried it on my laptop--it was found and i backed up about 80%--then my laptop gave error...
Sounds like HDD is failing, try downloading free recovery software from a freeware site...
Don't hold your breath though, it may not recover.
good luck !
Mar 30, 2017 | Maxtor OneTouch III Turbo Edition...
Just got new computer w/vista. Cant download maxtor software
Try this link. It has a software for Vista for your Maxtor drive. Download the ZIP version and install it. Hope this works for you .
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-emc-vista&vgnextoid=b6623428ab622110VgnVCM100000f5ee0a0aRCRD
May 14, 2009 | Maxtor OneTouch III Mini Edition (R01E100)...
I have seen the following external hard drive on Megabuy's web site but I canno see it anywhere else. Not even on the Maxtor site. Does it really exist and if so how does it review? Does it come with EMC...
yes it is true that maxtor has launched a hdd of the specification as mentioned in your post.
the same exists on maxtors website as well
the hdd comes along with one touch software that is used for data protection and recivery and has the same features as emc retrospect. further you can download the one touch software from
http://www.seagate.com/www/en-us/support/downloads/
Aug 20, 2008 | Computers & Internet
Purchased Maxtor ONE TOUCH III. when I had XP. Now that I have Vista, mAXTOR DOESN'T RECOGNIZE IT. iS THERE AN UP-DATE? nEED HELP. Thanks Marty xmartico@san.rr.com
Hey xmartico,
If your recent update from Windows XP to Windows Vista has been the only major change to your computer system since you could access your Maxtor One Touch III last, you may simply need to reinstall the Maxtor software to resolve the problem.
Information provided by the manufacturer has suggested that if no password was ever set, the hard drive should work with Vista immediately with no additional work required. If you had chosen a password however, you may need to reinstall the software and reboot every time you disconnect/shut down the external drive, or disable your user account control (UAC). Please keep in mind though that disabling UAC is strongly discouraged, as it may open your computer to attacks by various malware programs including viruses and spyware.
If you're still not quite sure how to proceed, I would strongly recommend contacting Maxtor directly for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 01, 2008 | Computers & Internet
Maxtor One Touch III mini drive problem
Hi
Please connect your hdd and go to disk management right click on my computer on the desktop g to manage and iskmanagement ..
check your hard disk is listed there or no if yes check it have drive letter if no please right click and add drive leter.if its there then check it has a format like it writng ntfs or fat32 if there then rigt click on the left hand side pan and say reactivate if still dosent work may be u need to format it. or use a third party software like hard disk regenerator or mac disk worior...
THANKSAND REGARDS
Jun 01, 2008 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor One Touch III mini ext HD 120 GB
I am not sure what model you have but the Maxtor hard drive downloads site has many system drivers, original software and Vista driver updates. The site is located at:
http://www.seagate.com/www/en-us/support/installation_assistance/installation_instructions/external_drives_&_personal_servers/ot3
If that does not work contact Seagate (they own Maxtor) at 1.800.SEAGATE (1.800.732.4283).
Feb 12, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Bought NEW MAXTOR ONETOUCH III (No software included???)
If you look at the site carefully you will see a small asterisk near the bottom that says * Windows2000/XP compatible. This seems to apply to several of the available downloads.
Aug 30, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Open Questions:
Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive Logo
241 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
