Question about Genius Wayne Submersible Sump Pump With Switch
I have wayne 3/4 horse switch genius pump whis is new. keeps on sucking air and will not shut off for several seconds making terrible air sucking sound thruout the house it is so loud. I have leveled the pump and it is free and clear of any obsticles. what can I do to get this to shut off after the water is gone without several seconds of this.
  • b812 May 11, 2009
    What an annoyance!
    Mine cavitates for 5-10 seconds after empty and the noise is brutal!
    It's going back so I can sleep again.
You can raise the switch in relation to the pump to ensure that shut off occurs before the pump starts sucking air. Somewhere between 1-2" ought to do it. The switch is attached to a 'spindle' on the pump through 2 holes in the switch. I unscrewed the spindle so that I could take the top switch hole off of the spindle while leaving the bottom hole on. Then I screwed the spindle back in. This allowed the switch to be raised in relation to the pump. I drilled two small holes in a plastic part near the top of the pump & secured the top hole of the switch to the pump body with string. Crude, but effective.
Posted on Mar 13, 2010
Ask for your money back. That's what we did. The pump turns on when the water reaches a certain height, but there is a minimum timeout. If you have a small crock, it will empty too fast and the pump sucks air and vibrates all of the piping. Sound deadening won't help that.
If you have a large enough crock, the pump may shut off before the crock is drained.
As an electrical engineer, I would never have designed such a flawed switch or allowed it to go to market.
Posted on Jun 24, 2009
    Novelist:
  • 152 Answers
I don't believe the genius switch is adjustable, as to the water level, but a possible solution is to better insulate the lid of the sump pump crock with a sound dampening material i.e. the use of Polystyrene insulation board, available in many thicknesses that can be easily cut (using just a hacksaw blade in a gloved hand) and fitted to your application.
Note: Do not seal the lid of the crock air tight, because some penetrations are needed to allow surface water to enter the sump pump area. Also make a penetration (just large enough to fit a piece of rope) at the center of the Polystyrene insert so as to install a short piece of rope with a knot tied on ether side of the insert, as a meg-shift handle for easy removal.
Hope this helps   good luck...
Posted on Feb 24, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: pump runs too long
Install a float switch that will switch-off the pump once the water reaches its level.
Posted on Mar 09, 2009
Where can I get an automatic pressure regulator as I was given the compressor without one and have to keep turning it on and off manually.
You need a pressure switch. In Ft Wayne go to Wayne-Vaughn. Bring the size of the motor, pump type model number and serial number.
Feb 27, 2016 | Air Tools & Compressors
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Are the genius switches any better than the float switches?
If you are placing a sump pump in a smaller, more confined area then yes. They both have their downfalls, and either can fail without notice. The ones that slide up and down the rod can get stuck or jammed, sometimes even due to build up on the rod. I tend to favor the genius switches, but either needs to be checked out periodically.
Oct 31, 2009 | Genius Wayne Submersible Sump Pump With ...
Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
Jul 14, 2009 | Genius Wayne Submersible Sump Pump With ...
No information on Wayne 55701-RP1
This isn't a valid Wayne pump model number according to Wayne's website. Please double check your pump and visit:
http://www.waynepumps.com/producttype.aspx?pt_producttypeid=8
May 23, 2009 | Wayne Water Systems Wayne RECONDITIONED...
Pump runs too long
Feb 23, 2009 | Genius Wayne Submersible Sump Pump With ...
Genius Wayne Submersible Sump Pump With  Switch Logo
1,233 people viewed this question
Top Genius Electrical Supplies Experts
Steve
Gene Haynes
Are you a Genius Electrical Supply Expert? Answer questions, earn points and help others
