Question about Kenmore 63942 Dryer
Kenmore Heavy Duty Dryer
I have a Kenmore Heavy Duty Dryer that runs for just a minute then it goes back off. Now it will not come on at all. No circuit breakers are tripped.
  • Surge2 Feb 26, 2009
    I had the same problem. It turned out to be a loose belt. I remember prior to the problem that the dryer was making an odd sound right when pressing the start button. Turned out the drum was slipping a little at start and later started triggering the belt switch and stopping the dryer.
  • 117 Answers
If the dryer is still powered on but the motor stops, it sounds like the over load in the motor is cutting out and the motor will have to be replaced.
Posted on Feb 26, 2009
My general electric heavy duty automatic electric dryer won't heat. Is there anything to try before replacing heater?
go to your fuse box and try replacing the 2 fuses for the dryer circuit or if you have a circuit breaker box shut off the breaker for the dryer and turn it back on and try the dryer again. I used to be an electrician and found double pole circuit breakers that have only one side tripped. alot of 220volt electric dryers use one circuit for the tumbler motor and the other circuit for the heating element
May 07, 2012 | GE Dryers
Kenmore elite dryer runs for about 3 min. then trips the breakers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
My condensing dryer trips my house circuit breaker,iread the manual,it says there are 2 fuses.is that the problem?how do i get acess to these fuses
There are no fuses inside the dryer that you can service. It does sound like the problem may be in the circuit breaker. Try doing a load and running the plug to a different outlet. You may have to use a heavy duty extension cord.
Good luck
Oct 03, 2010 | LG Dryers
Kenmore heavy duty. its working properly but not heat
Power from the house:
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element:
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse:
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring : A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
thanks and keep updated.
Jul 08, 2009 | Kenmore Dryers
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer
dryers take a lot of power to run.the circuit is tripping because it cannot take the load of the dryer.you may have to get a dryer line installed.check the value on the circuit breaker.u need to use twice that value on the dryer.with clothes added to the dryer the motor takes more current to spin.this extra current is greater than the circuit breaker value so it trips to prevent the house wire from going on fire.
Jan 07, 2008 | Kenmore 63942 Dryer
Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Dec 18, 2006 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
349 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
