Question about IBM ServeRAID-7k Controller (71p8642) SCSI Controller
Unable to setup my raid on a IBM XSeries 346
I added 4 hard drives to my server and when I boot the box I see it's setup as a raid1 and I would like to change it but cannot find where to do this. The box has a IBM ServeRaid 7K ver 7.12.0.2
Dear steve :
you can try to solve this problem use serveraid support cd.
Posted on May 05, 2009
    New Friend:
Ok muchas gracias me sirvio de mucho la liga
Posted on Mar 05, 2013
Hello I have a query guys on hp ML350 server is that at the end of the inauguration of Windows blue screen appears You change the RAM first and then reduce Alhardat from three to two, but without the...
The system is not designed to use IDE hard drives which why you are getting a blue screen. It is designed to use SCSI hard drives and IDE CD/DVD drives. It might be possible to go into the server's BIOS setup and change the boot device from the onboard SCSI controller to the IDE controller. It is very likely that you will have to disconnect all SCSI devices to boot to IDE, if it is possible.
I hope this helps.
Nov 27, 2012 | HP Compaq ProLiant ML350 G3 Server
I have installed windows 2000 server and i am getting problem in booting of os. when there is cd of ms2000 present in the cd drive the os boot properly while if i remove cd from the drive and start the...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 15, 2011 | SuperMicro X6DVL-EG2 Motherboard
My Toshiba at start up it says check cable connection PXE-MOF: exiting intel PXE ROM No bootable device -- insert boot disk and press any key
If I understand you well, before Windows loads, you get a notification about the ethernet controler which is waiting for a boot data stream to come from a local server. If you don't use a client-server network setup, you'll need to go to BIOS and change the boot options, so that your hard drive is set as first boot device, then DVD as second boot device, then USB drive as fourth boot device, and lastly LAN as fifth boot device.
What happens is that your PC thinks that the LAN is the primary boot device, and in corporate networks PCs get such a setup so that there's one large server feeding data to the local cubicle PCs. In some cases the server-dependancy is set to such extent that these cubicle units are just "dumb terminals". In your situation, your PC thinks it should also get boot infro from the LAN, but as your PC is not a part of a corporate network it waits in vain, and after a while it should move on to the second/third boot device, and eventually find that it has Windows installed localy and starts loading the OS.
So, to wrap up, you'll need to go to BIOS and set your local hard drive as the primary boot option. This will fix the problem only if your hard drive is OK and you've installed Windows on it.
If your hard drive is failing/gone, then your laptop may not even recognize it and therefore moves on to the next bootable device, which is usually the DVD, and then a USB drive and lastly LAN boot.
Anyway, go to BIOS, and see what is the current setup. If the hard drive is set as first boot option, then this is a good sign that you'll need a new drive.
If this was informative please give it a Thumb Up. Thank you.
Jan 20, 2011 | Computers & Internet
What hard drives can I use as replacements?
Call Dell with your Service Tag.
Lifetime support is included on all Dell servers.
Last time I called them I dialed (800) 945-3355
They can sell you the hardware you need and guarantee it will work with your server. They might even be able to help explain the process of installing the drives.
I recommend that you use Acronis' Imaging software (www.acronis.com) so that you can make an exact copy of your data and apply it to the replacement volumes. If you are using a RAID1 array make sure the new array is completely built before applying your image. Builds can take a long time. I created a RAID1 array with 2-320GB disks and it took 3.5 hours to build the RAID1 array.
I hope this helps.
Please vote for my solution if it helps.
Apr 19, 2010 | Dell PowerEdge 2500 Server
Unable to boot from HDD1 position or recreate RAID1.
you need to go into your bios and tell it to boot from the other hard drive make sure you plugged in the right wire to power it it should be the same as one used for the hard drive that works and plug it in tightly.
Nov 20, 2009 | Toshiba Qosmio G25-AV513 Notebook
USB ports appear to not be working. Any clues?
Go to setup turn on the USB 1.1
The USB port is turned off for security reasons;
You may consider adding a 4 port USB 2.0 adaptor card my server has Both I use the onboard USB 1.1 for external hard drive and mouse
Nov 19, 2009 | Dell PowerEdge 4600 Server
Does 206M supports SATA Drives 500GB as well as
Enter BIOS SETUP, and check the "boot order" (after connecting the SATA drive) -- ensure that the SATA drive is *NOT* the *FIRST* boot-device.
Oct 23, 2009 | IBM eServer xSeries 206
Can I add additional drives to Raid 1 in order to expand storage?
I am not familiar with the specific model, but my guess is you can setup another separate logical vlume by using a RAID1 for the new disks. You will not be able to add the disks to the existing volume.
If there is no data, and the array supports it you can delete the existing volume and setup a RAID 5 instead, which will use all 4 disks, as long as they have the same capacity.
Apr 22, 2009 | Intel SS4000-E (SS4000ENA)
Supermicro machines
Your server uses a Super P8SCi Motherboard, and according to the manual for your server on page 4-2, you can enter the bios of the computer by rapidly pressing the DELETE key when you first power on the server. This will take youto the bios setup screen. At the top, you'll see an option called boot. Use the arrows keys to navigate over to it, and change your first boot device to the CD-ROM Drive. Then SAVE AND EXIT, and it will now boot from any cd before looking to boot from the hard drive.
Steven
Sep 09, 2008 | SuperMicro (SYS-5014C-T) (SYS5014CT)...
Ghost array0 over to newly setup array1 problems
I should assume the CD drive is SCSI? What sequence is it set to come up in? Set it at 2 if possible. Have you checked, or better yet replaced the CD drive? Will it boot with ANYTHING else?
That Hiren's CD is not uuummm, kosher? People having problems booting with it and all, plus the utilities may not have full function anyway. No matter what, you will need to f/disk the destination drive. You will still need the CD drive to install the program too.
Backup software will still make an exact copy of your drive also. You might want to consider a little better product, especially concerning disaster recovery. not to get off topic but, a quote from J. Bolton on backup & recovery
"What will you do if a user overwrites a 1000page doc with a blank file with the same name? What will you do if one of multiple server apps goes bonkers? If the mainboard dies how will imaging get your system back? Do you stock a spare board so the image restore will work on the exact same hardware? After a system crash, Acronis True Image Enterprise Server allows you to perform a full system restore, a bare-metal restore or just a restore of individual files and folders.
Complete system restoration can be performed to an existing system, to a new system with different hardware or to a virtual machine. You could setup a whole new system and dump the image on that.
Dec 04, 2007 | Dell PowerEdge 2600 Server
IBM ServeRAID-7k Controller (71p8642) SCSI Controller Logo
5,826 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
