Question about Alpine CDA-9887 CD Player
What is the audio interrupt in lead wire ?.remote turn on lead ?.and were do i hook them up ?
    Novelist:
  • 152 Answers
The audio interrupt lead = A wire that is typically is connected to a hands free cell phone system.
The turn on lead = Is an activation wire that is typically is connected to an optional amplifier.
Hope this helps.
Good luck...
Posted on Feb 24, 2009
I hav a alpine cda-w925ehi head unit an it just stopped an now says "interrupt"
Hi I believe you have an Australia model? Alpine's use what's know as an interrupt wire to hook into vehicles/phones to interrupt the audio of the deck when their is a signal sent to it. On the Alpine harness you need to search for the Pink/black striped wire which is the audio interrupt wire. Make sure that wire is insulated and not grounding out against anything or hooked up incorrectly.
-Boz
Nov 28, 2012 | Car Audio & Video
My legacy la1495 amplifier will not come on,but there is power going to it
Is your remote turn on wire installed and the cables hooked up correctly? You can try jumping the 12vdc on the amp to the remote turn on lead to force it to turn on to see if it's a deck issue.
Nov 22, 2012 | Legacy Audio LA1495 Car Audio Amplifier
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
Unit comes on but has no sound where does the audio interrupt wire go does it have to be hooked up to hear it?
the audio interrupt wire does not need to be hooked up for the output to work. make sure you have no bad speakers or shorts in the speaker wires. you may want to make sure the interrupt wire isn't shorted to anything also.
Jun 16, 2010 | Alpine CVA-1005 Car Video Player
No sound
if it is a aftermarket radio recently installed then most likely hooked up the power antenna wire to factory amp turn on lead instead of remote turn on lead so what happens is when the tuner is on the power ant lead supplies power the amp remote on wire but when you insert a disc that cuts power to the antenna lead and turns the amplifier off
Mar 12, 2010 | Car Audio & Video
05 MBZCLK320 The volume knob spins but no sound
if it's an aftermarket deck make sure the remote wires are hooked up correctly..some wiring harness' require you to hook up your headunits remote lead to the blue remote lead on the wiring harness...also if you have woofers attach all 3 of those remote leads together..
Jan 31, 2010 | Car Audio & Video
I have checked all connections to my amp battery,head unit,remote or trigger wire,fuses,power cable,rca leads,ground wire,amp has a green led light on it indicating if it works ok,red if it`s not,light...
Your amp could be in protection mode! Sometimes turning up to high or wires touching will put in protection mode! It will have to be unplugged for a day or two to drain all power out of the memory. Leave accessorie/ignition wire hooked up, just not power and ground wiring. It should reset itself.
Jan 22, 2010 | Lightning Audio B4.250.2 Car Amp
Wiring an alpine cdm9807 rb to a citreon berlingo van
The 'illumination' wire is to hook up to your headlight switch to back-light all buttons when headlights are on. The pink and black audio interrupt I believe is for hands free cellphone communications it will cut out audio when you have a call and have your hands free hooked up through your stereo. The remote turn on is for external amplifiers it provides a small amount of power to to turn on/off external amplifiers. As far as your unit not working I would make sure you have a sufficient ground using a voltmeter and make sure your battery lead is fused and fuse is not blown. You should have a memory lead(maybe yellow) that need constant 12v and a ACC power that needs switched power that is only on with key(usually red). Hope this helps! :)
Feb 25, 2008 | Car Audio & Video
Remote wire hook up
The Remote wire should connect to the remote turn on lead from you radio(most aftermarket radios use a blue and white or a blue wire for the remote turn on). This wire will send a 12v signal to the amp from the radio when the radio is turned on. You can disconnect the remote turn on lead from the amp and jump a wire from the terminal marked battery to the remote turn on terminal just to see if the amp powers up. Do not leave it this way however because your amp will not shut off and your battery will go dead.
Aug 19, 2007 | Rockford Fosgate Punch 301S Car Audio...
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Alpine CDA-9887 CD Player Logo
3,229 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
