Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Convergence off line
I have a 3 year old RCA 52 inch Projection screen televison model # D52W20 . The convergence is off, when I try to reset it with the remote control it just won't reset, I tried unplugging it and moving it ;How do I repair it?
  • 1 more comment
  • snu66les2 Mar 02, 2009
    I fixed it!!!!!!!!!!!!!!!!!
  • averagesmuck Mar 04, 2009
    Hi I was watching tv on my 52"rca and then the convergence went out all the colors are way out of wack and on the setup menu there used to be an auto convergence and it s not there any more please help
  • jcarl2210 Mar 05, 2009
    My convergence is off and it wont auto fix it and it wont let me manually fix it by moving the red cross over to the green cross. It comes up i see the red cross but it wont let me move it. What can I do please help!
How did you fix it?????? I though I tried everything!
Posted on Mar 04, 2009
I need a convergence kit for a rca 52 inch rear projection tv
what type of problem with convergence? no convergence at all? pitcure bowing? this in the setup menu do you have the convergence option? a convergence ki in a standad porojection has stk ic/s this model does not .you might have the fl231 fuse problem.. generally its board replacement. then the problem becomes alighnment.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52 inch RCA model # R52WH73. The picture is blurry and double. What do I need to do to fix it?
Ur convergence is dead,need a convergence kit,know how to solder right?Tries these websites.Tv Repair World.com,Ebay.com.
Oct 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca projection tv turn tv on and there are horizontal
Go to menu then setup look for convergence if you Do NOt see convergence then you have a open fuse FL231 Located on right side of FBT there is 3 in a roll small brown rectrangle looking caps but they are Fuses it will be in the one in the middle.
Aug 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi I have a 52" RCA big screen tv that is only 3 years old however we turned it on today and it is showing some red blue and green lines and the picture is blurry
Hello clara7,
This denotes a convergence problem. I would suggest that first you enter the menu of your TV ad try to do an auto converge on your set, if this does not work I would suspect that the convergence ICs have gone bad and need to be replaced. I would suggest that you have a qualified TV repair technician replace the convergence ICs in this set.I hope this helps,Shuttle83http://www.electron-age-technologies-llc.com
Jun 08, 2009 | RCA P52939 52" Rear Projection Television
52 inch rca shows picture in 3 colors will not focus
is thr convergence adjustment option still listed in the on screen menu? Let me know and I will try to assist you.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV 52 Inch
If its only one color its the Convergence amp board that needs replacement. If its more than one color you cant control you need the Convergence power supply board. If you need parts for your model let me know and I will post a link.
Jun 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
358 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
