Question about Leviton 104-05611-2WS 15A Decora Single Pole Illuminated Switch with Ground
We just started getting shocked when we turn on some of our light switches never had this happen before it started hapening right after we had lost power does anyone know what might cause this? Thanks Angela
    Novelist:
  • 152 Answers
Angela
It sounds like a static electricity issue to me, and if so there are many products on the market to eliminate this. The most effective are anti-static carpet spray's that can be purchased from a local carpet dealer or supply. You can research other remedies on the web.
Tip: You can create an inexpensive anti-static spray by mixing laundry fabric softener with water 50/50 into a spray bottle. Lightly mist this spray on carpets and other surfaces to prevent static buildup.
Hope this helps
Good luck...
Posted on Feb 24, 2009
1997 kawasaki prairie 400 4x4 automatic
get a service manual. could be anything from the starter switch to the solenoid
Mar 10, 2014 | kawasaki ATVs
Lights, radio and powerdoor locks work, turn key to start car nothing happens
If you had said the radio did not work, I would say it was the key switch or a large fuse or fuseable link.
But the radio is powered thru the key switch.
The problem could still be the key switch or a major fuse, I would check all of the fuses then power at the key switch.
Also check the ground connections.
Jul 18, 2012 | 2003 Oldsmobile Alero
Why do I get a rattling sound in the rear of my 2004 GMC Yukon Denali XL every time I start it?
It is the compressor to the shocks. It hapens when the shock has a leak. It's called air ride system. it's very annoying disconnect the power going to the motor behind the driver rear wheel or fix the air leak
Sep 17, 2011 | 2005 GMC Yukon Denali
Air suspension fault light came on in my 2004 jag xj8. a day later vehicle to low light came on. watched the suspension and it continued to work with this warning lights on. a week later the right shock...
if your in doubt about the functionality of the suspension system a quick way to check and see if the static pressure system is working properly is totake a floor jack and raise up the opposing side that you have questions..The system stores 228ps in the retantion tank located under the spare tire.As you force the air to one side the recycle valve will release the air to lower the cars' body.You wil hear it come out,then lower the jack,then the air from the tank will refill the lost air....Turn on the car to initiate the air pump to refill the rear tank,you should feel the car raise up in the front evenly.Last but not least my suggestion is if you think another shock is leaking you can 1st check the caping on the shocks...at times they will leak slowly on the caping...it will start as a weeping leak and you cant hear it....you can get some soapy water and lightly spray it around the enter deck mounts location under the hood where the air lines feed into the shocks...if you see air bubbles,then you can easily pack a towel in the leakage until you find a used shock or rebuilt one off ebay....But you fault light wont display a mil.The fault light only comes on when pressure is lost from the shock,or a static line has failed...causing one shock to lower to be lower..The CAN will trigure a fault code as the sensor detects body uneveness..Usually when this happens you will see a fault code,but I doubt this is your issue.
Jun 21, 2011 | 2004 Jaguar XJR-Series
My car recently lost power. the engine will start and the car will go, but it will not go any faster then 10mph and it can not go up hills without loosing power. also the check engine light came one once...
how many miles? a high miler will lose compression in cylinder and cause this problem.Anytime the check engine light comes on go to autozone parts store and get it read for free they will thell you what codes mean and let you know whats wrong.
Mar 16, 2011 | 2003 Mazda Tribute
My friend just installed my subwoofers into my car. They are Dual 12 inch 1100 Watt speakers with a Pyle 1400 watt 2 channel amp. He installed his own speakers in his car so i trusted him with mine. He...
your getting fead back. check the ground on the amp it needs to be bare metal and tight also check the rcas they need to be tight and if its only hapening wile u play the ipod try switching wires from the i pod it hapens all the time with aux cables they break easy.
Sep 28, 2010 | Dual Car Audio & Video
Powering up
I think the battery is the problem. But does it power up when connected to the power?
Also please mention the model number.
Do you remember what hapenned the last time it worked ?
Nov 16, 2008 | Acer Computers & Internet
1998 Jeet Cherokee with random starting problems.
Check your neutral safety switch, it is supposed to prevent starting in gear and it sounds like it is time to replace it. countrycurt0
Oct 08, 2008 | 1998 Jeep Cherokee
Blinking lights
Next time this happens, try pushing in the door handle. If it starts up again, the computer thinks the door is ajar, and it won't run. You'll need the door latch assembly w/ door switches.
Mar 24, 2008 | Kenmore 15632 Built-in Dishwasher
Leviton 104-05611-2WS 15A Decora Single Pole Illuminated Switch with Ground Logo
94 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
