Question about Canon imageCLASS MF6550 All-In-One Laser Printer
MF6500 shooting blanks
Trying to make copies and only blank pages come out.  Tried changing toner but that didn't make any difference.
  • data1701 Mar 01, 2009
    I just changed my toner cartridge and now blank pages. Put the old cartridge back in (which was still working) but still blang pages. Will call Cannon Monday March 2, 2009 for advice and if needbe repair. Unit is two years old.
  • 3 Answers
I hope you still have your copier and have not yet sent it in. I had the same problem and when I called Canon Tech support, they told me to go buy a new CANON brand toner cartridge that costs from $150 to $180 each to see if it would fix the problem. Obviously, if this did not fix the problem, I cannot return the toner for a refund. I was using a knock off brand that cost me $40.
I found that the problem is a metal shutter that is inside the machine behind the toner cartridge. It is a metal shutter about 1/4 inch by 4 inches that moves up and down to protect the user from the laser. Your shutter is not moving up out of the way of the laser. What I did was grab the center of this shutter with a hemostat (or long thin pliers) so that it bends this shutter just a little bit, then I pushed the shutter upwards with a butter knife. This little bend in the metal shutter causes the shutter to stay in an upright position by friction of metal on metal. Now it copies fine, even with an offbrand toner cartridge. It saved me hundreds of dollars on repairs or replacement parts.
I think that Canon tech knows about this, but they make more money when they replace a whole new laser unit for you or charge you for repairs.
Posted on Mar 16, 2009
  • 136 Answers
Well chance are they will make you send it back, they will most likely NOT come out since you bought this product from Staples or Office Maxs. If they do tell you that they are coming out , tell them that a Premier Authorized Imageclass Canon dealer, adviced the service technician that they should bring a Laser unit with them or repair yours. Yes we areCanon Authorized Dealers- for the Imageclass series.
The problem with these units are that the Shutter on the laser unit " the spring" breaks or pops off and refuses to open the shutter when the cartidge is installed. So chances are this is a defect from Canon an is a common problem. So tell the Technician from Canon to " BRING A LASER UNIT"
Posted on Mar 06, 2009
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
I changed my toner cartridge today and now it's not copying
Having 2 (defective?) cartridges that behave in exactly the same way seems too unlikely to me. So I have to ask the obvious question....did you pull the seal to release the toner? If it's an original there should be one, if it's remanufactured, there may or may not be one on it.
Jun 20, 2009 | Canon Office Equipment & Supplies
your laser shutter is not opening properly you will need to have serviced by service tech
Mar 04, 2009 | Canon Office Equipment & Supplies
Printing blank pages
open the door and look for a unit that has some small hair like wires, are they intact or is one missing /broken???
Oct 30, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Not printing (paper comes out blank)
it is possible that is has problem on your printer's memory... try printing below 30 pages see if problems still persist.
Mar 07, 2008 | Samsung CLP 300 Laser Printer
Printing and copying almost blank pages
Ussally drum/toner would fix, will not be fuser, I would suspect Hi voltage board or laser unit, In australia these machines carry a 2 year return to base warranty.
Try reseting the drum counter, this also resets Bias voltage, might be your problem. open front cover with power on and press set, arrow to change drom and select yes.
Otherwise it would be a high voltage board problem, possibility alsoexist that it could be laser unit
Check status page for "71" errors, menu * 2 8 6 4 very very fast, machine will beep "maintence displays" then 77 to print out status page, 99 to return to normal.
Nov 26, 2007 | Brother MFC-8440 All-In-One Laser Printer
Blank copies
Thanks Guest with Best Solultion! OMG! I have had my machine printing blank for over a month now and reading stuff and trying to find a solution. Until finally today I found this page. I read your solution and hit the front like u said for several times and nothing. Finally, after the third try WALA...IT WORKED!!! Thanks again. If anyone has this same problem try this because it really works! Eventhough this is such a strange problem for such an expensive machine.
Oct 04, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
Can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
Aug 01, 2007 | Brother IntelliFax-2820 Laser Fax
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
506 people viewed this question
old marine
old marine
