Question about Xerox WorkCentre Pro 785 Plain Paper Laser Fax
We have the Xerox WorkCentre 665 and it's printing so light.
It is printing, but so light that we can hardly see it. This happened after they added more toner
  • 239 Answers
You can pull the developer houseing out. Wipe the mag roll, so it has a shinny area.
in a small area. Enter the developer housing in again.
Try running a copy.
Remove the developer housing and see if the mag roll moved. If it did not and it is still shinny and clean, this is the problem with light copies. Possibley bad developer housing or ciruit boards. Both are costly.
One other area is, if the developer housing is working, see what brand of toner you are using on this machine?
If it is a brand other than Xerox, dump it all out.
The developer housing has to be completely emptied.
Enter the Xerox toner and see how it works.
Also, a bad Transfer corotron can cause this problem, it may be arching in the blocks.
If all else fails, call Xerox for this major repair.
Posted on Oct 17, 2009
Xerox color 550 has its control panel lights flashing, and printer wont start up
This http://forum.support.xerox.com/t5/Printing/7428-Shutdowns-All-Lights-Flashing/td-p/164967 says do this, carefully.... http://www.support.xerox.com/support/workcentre-7425-7428-7435/support/enus.html?objGUID=17471 good luck with that one. sounds a bit like the sort of issue an old hard drive might give you.
Oct 03, 2017 | Xerox Office Equipment & Supplies
XEROX WORKCENTRE 7328 IS RUNNING SLOW WHILE PRINTING PDFs
Are you printing to the printer using the Xerox Global Print Driver PCL6? If so, this will be the cause of your problem. Earlier versions of the driver werent as bad when processing PDF documents. I would suggest that you download the Workcentre 7328 PCL6 driver and try that - the problem should clear.
Cheers
Jon.
Dec 17, 2010 | Xerox WorkCentre 7328 Multifunction laser...
My xerox 3119 frequently pick up more than 1 paper during printing. It cause paper jam and make it very hard to print of both side of the paper. Can you help me solve this problem?
The xerox laser printer rollers have shrunk, causing the paper to be picked up in multiple.
Try to fan the paper before adding it to the paper tray.
Aug 11, 2010 | Xerox WorkCentre 3119 Laser Printer
Xerox Workcentre C2424.
You likely need modify darkness or the contrast.
Please take a look at the following from the Xerox site:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=458,E=0000000001668056207,K=4248,Sxi=0,Case=obj(6796)
Please let me know if this has been helpful or if there is anything else I can do. Thank you.
Sep 19, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre 470 cx problems
Those are referred to as the dots of death.
Most frequently the hard drive has failed.
Possibly firmware corruption or a main board failure. Normally not good.
Feb 23, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox XD100 does not work
When you saying No working , What Happens when you press the print Button can you manually get this copier to print out ?
Has it stop printing only ?
Feb 19, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre M15i squeals when printing and copying.
Do not only lubricate metal shafts, but promptly lubricate the "pulleys" on the right and left side.  the will look very similar to a wheek and pulley mechanism.  The squeal happens when one "bar" connects two "wheels" and one side moves faster than the other.
Jan 23, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD100 driver
That very much sounds like a driver problem.
One thing you may try first is when you get to the download page for the drivers.Select ALL on the driver page. Normally you get one selection to show up when you just click on the driver page. When you click ALL then Go and you will see more options.
There is not a Vista driver for that product if that is your operating system.
Maybe just delete the printer and re install. Something is wrong with your driver, corrupted or just not functioning correctly.
I do not have my laptop with me right now, I left it at the office with my other documentation on it.
I will look up more in the morning for you.
But this very much strikes me as a corrupt driver problem.
Jan 02, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre Pro 785 Plain Paper Laser Fax Logo
186 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
