Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
No hot water
We have 4 showers running at once with two rtg 74pvn hooked together with easy link hot water only runs for 5minutes
  • XXXDRJohns May 11, 2010
    Are you getting any type of error code being displayed on your remote?
  • Scott Magill May 11, 2010
    Did you just have these installed or have they been in for awhile? have you checked to see if both heaters come on or if just one? have you checked to see if they are piped right? If they have been in for some time then i would check to see if filters need cleaned. I would also have gas pressure checked when both of them are running on high fire to make sure they have enough gas pressure.What size of gas line do you have going to each unit? Do they work fine when you run one or two showers?
  • 332 Answers
There are filters on the shut off valves one of them could be clogged in wich case you are only using 1 unit and the 74 can not keep up with 3 showers, how long have you had these units? write me back gary1121@aol.com
Posted on Jun 06, 2009
Rheem RTG-74PVN-2 code c776
Communication fault with remote, but also bad PC board.
Copy following link for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 13, 2012 | Rheem Tankless Hot Water Heater...
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I have a Paloma PTG-74PVN tankless natural gas water heater. It was installed 3 years ago and has worked great until 2 days ago. Currently, the water heater will run for approximately 10 minutes, i.e....
Try turning the thermostat uo a small amount and see if this makes a difference. I suspect the control board is bad but I would try adjusting t-stat before I spent money on board or service call. Thank you
Dec 16, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water is hot until you adjust the shower temperature to warm from hot, then heat unit shuts off and it is 100% cold. Shower head is low flow so wonder if the flow is below minimum for heater to fire?? Can...
These unit is design to operate at a specific flow rate and cannot be ajusted if you need to have a warm shower you will need to get a bath remote where you can turn down the temp whenever you need without disrupting the flow rate
Jul 21, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem tankless rtg 74pvn - heater hot water shuts
This is something you will have to contact rheem about due to the fact you don't have a fault code
Jul 13, 2010 | Rheem Tankless Hot Water Heater...
My paloma tankless water heater will shut off in the middle of a shower
I am not sure if this is it but I had mine at too high of a temperature therefore I was not using enough volume of hot water to keep the heater on. They have a minimum amount of flowrate to sustain. Try turning the water temp down to 125-130. Hope this helps
Jan 27, 2010 | Rheem Paloma Tankless Water Heaters...
Hi, I have a Rheem RTG-74PVN-2 tankless hot water heater. It has run great for about a year, but now shuts off completely after running for approx. 8-10 minutes. I have the water temp set at 130 f. Any...
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end. See if the unit runs longer.
If you're receiving any error codes, especialy code 76; contact RHeem customer support at (800-432-8373) and notify them IF you are getting a code "76" error.
Good luck,
JZ...
Nov 25, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
121 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
