Question about PANDIGITAL 11-Inch LCD Digital Picture Frame (PAN111-B)
Picture Frame is not turning on
I've had my Pandigital for over a year and it's worked just fine until now. I've checked on several plugs in my house, made sure it's plugged in appropriately and it still won't turn on. I hear a difference in sound coming from the plug when I turn it on and off. Could it be that I need a new plug/adapter?
I just bought my parents a similar Pandigital frame for Christmas, uploaded pictures for them and it was working fine. They took it home and now there's is not working either- same thing - they checked on different plugs and made sure it's plugged in correctly.
What could be the issue?pan digital photo frame just stopped turning on
  • 10,594 Answers
If it is under warranty then ask for warranty cover to store.
No schematics are available for Pandigital photo frame to look for problem.
Local repair shop might help you if unit has no warranty.
Posted on Feb 23, 2009
    Brigadier General:
  • 3,614 Answers
HI,
is there any power coming from the photo frmae.
try changing power cord and check the output input voltage.
Picture frame will not power on
seems to be a problem
http://www.fixya.com/support/t4207203-dpfmate_wont_charge_tried_turn
Try connecting a USB cable and see if you can suck your pictures back. Weren't they on your computer anyway?
http://www.cnet.com/products/pandigital-digital-photo-frame/#!
Oct 23, 2015 | PANDIGITAL (DPF802) Digital Picture Frame
I cant get my pandigital picture frame to work. i have plugged it in and turned it on and wont work. so what can I do to make it work?
In the event that your device does not respond to your touch, you can reset it by poking a straightened paper clip into the small reset hole on the top of your device, and then turn the unit back on
Dec 16, 2014 | PANDIGITAL 7" Digital Photo Frame With...
My Pandigital 7' EReader won't turn on even when I charge it. I had it on playing a lullaby for my kids and now it won't turn on. Please help.
plug it in then push power+volume up for 30 seconds or until a message appears for 1 second easy to miss so dont blink until you see it then let go and press power button until it boots
Dec 19, 2010 | PANDIGITAL 7" Digital Photo Frame With...
My Pandigital frame was working fine for a couple of years and now the screen is totally black.
that is probably the back light system neon where they defective
or the power supply its self
it is probly an easy problem to fix by a good technician...
good luck
regards allan.
Sep 01, 2010 | PANDIGITAL (DPF802) Digital Picture Frame
My pandigital photo frame is frozen on the sytem start screen
Mine does this when the power cord shorts itself out. For a whileI could fix it by simply untwisting the cord close to the plug, but eventually I had to cut and splice the cord to keep the lines separate (think a bunch of electrical tape. It works fine now that the cord isn't shorting out. Hope this helps!
Feb 02, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
there must be abreak in wires of in put cord
Apr 11, 2017 | PANDIGITAL 11-Inch LCD Digital Picture...
SD Memory Card in frame-no pictures
1st: Make sure the SD card is in working order and not damaged.
2nd: Make sure you're using the right file type (.jpg, .png, .gif, etc) and size.
Jan 06, 2018 | PANDIGITAL (DPF802) Digital Picture Frame
PC will NOT recognize my photo frame
Quite possibly your OS is not the correct one that the pandigital can use .I have thrown several away thru the years , for the same reason .
Apr 14, 2017 | PANDIGITAL (DPF802) Digital Picture Frame
USB Connection
Hi Amanda and Lisa. Are you making sure the picture frame is off BEFORE you plug it in to your computers? Make sure you:
Turn it off before pluging it in, then plug in the USB cable. Now you can turn on the picture frame and you should see the frame's memory and any SD cards you have plugged into it in the removable drives section.
Let me know if that helps. If not let me know, and thanks for coming to FixYa. If you're happy with my answer then don't forget to rate it appropriately.
Rob
Dec 23, 2008 | PANDIGITAL 8.0" Digital Photo Frame...
I NEED A INSTRUCTION MANAL
I got my digital "pandigital frame last year and lost the instructions. Can you tell me how to download photos from my PC via Usb to frame?
thanks Deejohn2127
Oct 29, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
PANDIGITAL 11-Inch LCD Digital Picture Frame (PAN111-B) Logo
527 people viewed this question
Top PANDIGITAL Photography Experts
LP
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
