Question about Whirlpool Duet GHW9150P Front Load Washer
FH error I am currently washing a load on Heavy Duty and it starts beeping 12 minutes into the cycle with F H flashing now. I can not get it to do anything. I even unplugged the maching, left out for 10 mins plug back in adn the machine sounds like its running, door locked and I can't do anything. What should I do?
    Habit-Forming:
  • 16 Answers
Check the strainers on the water inlet valve behind the washer. Make sure they are not obstructed by rust. You need to remove the hot/cold hoses to view them.
Posted on Feb 25, 2009
  • 117 Answers
I found this for ya, it explains why you have an FH error code.
http://fixitnow.com/wp/2006/04/09/whirlpool-duet-kenmore-he34-washer-f11-and-fh-fault-codes/
Hope that helps ya!!
I have the CW447 integrated dishwasher which won't fill with water
Like most electrical appliances what worked for me was turn it off at the wall for 10 mins, then turn it back on. Did you get an error code? Check the pipes are not twisted and that the water supply is turned on full. Let me know how you get on
Apr 13, 2014 | CDA WC430 Dishwasher
Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't transition to wash cycle. Flashes FH error code.
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer problem
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
First, try to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, then proceed with the steps outlined in the link I provided for you.
This is one of the more "involved" error codes that you may need spend some time with. Although, it may NOT be a difficult repair, it still may require some diligence to figure out the cause. I would recommend checking your washer installation for a potential siphoning problem and then check the drain pump as these are the more common causes. If you require additional assistance, please let me know. I hope this helps you.
Jan 04, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
turn the water supply on,, f/h is a fault occurring when ther is no incomig waterdetected
Apr 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
870 people viewed this question
Dan Webster
Dan Webster
Sal De
