Question about Acer Aspire 3000 Notebook
I have an error in my pointer command
I installed a wireless mouse which allows mew to move around. But now I can type anything on my keyboard and I can't log on. I thik it might be a function key problem ?
Any suggestions . I am using another computer to send this message.
Mouse moving all around
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Dec 03, 2010 | Dynex Wireless Optical Mouse
Mouse pointer won't move can't control movement
try installing drivers from the site maybe threre is a new firmware
May 19, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
Sep 16, 2009 | Toshiba PA3121U - Satellite Pro 6000,...
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
Wireless Mouse a Problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
MY GE WIRELESS OPTICAL MINI MOUSE POINTER MOVES ON ITS OWN
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
Nov 24, 2008 | GE Wireless Optical Mini Mouse 3087897985
Moving mouse, interrupts typing on MS Wireless Keyboard Combo
1.?Open the Start?Menu and click Devices?and?Printers . The Devices And Printers panel opens, in which you can access all the external devices connected to your computer, including your printer .
m-ydpxpf3wblkuljzof3anecxv-4-0.png Windows 10 - Control Panel - Keyboard - Settings
Apr 11, 2017 | Microsoft Multimedia Optical...
Dell bluetooth wireless mouse pointer misses the mark
reload the drivers again that will solve the problem ! make sure they are updated!
Oct 12, 2008 | Dell Wireless Keyboard Optical Mouse w0147
how do i get the battery out of my mouse .
Jan 01, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
