Question about Xerox FaxCentre F116 Plain Paper Laser
Don't want a transmission report after each sent fax
Hello, we allow two other departments to share our XEROX FAXCENTER F116 fax machine. Someone has set the machine up to print out a confirmation transmission after each sent fax. I don't have the book and need to stop this needless waste of paper. Please help!
Also, can I lock the fax machine so no one else can make changes but me and still allow faxes to be sent?
Thank you, Debbie
  • 239 Answers
On the machine there is a menu button.
the menu can be printed out so you can see all the areas to select.
If you scroll to through the menu, you will find a set up or incoming fax menu.
You need to set confirmation to off.
This will take some time to find the right menu, so be patient with the machine.
Good luck.
Posted on Oct 17, 2009
I have a xerox f116 faxcenter machine that I bought from an online auction. When I set it up and put a document in to fax, it came up with a message that said 'REMOVE DOCUMENT STOP TO CONFIRM'. The...
Go to the link below and see page 116 for your solution. The link below takes you to the users manual for your model unit:
ttp://download.support.xerox.com/pub/docs/FaxCentre_F116/userdocs/any-os/en/userguide.pdf
May 25, 2011 | Xerox FaxCentre F116 Plain Paper Laser Fax
I can't get an F116 to work. SN VFF243779
If no lights display or sounds, it maybe a low voltage power supply, it is mounted on the back.
A service call maybe needed for this repair
Dec 20, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Coming from a law firm legal department background, I have been known in the past to run off too many docs on the printer/copier a kill trees. I am working very hard to start "greening" my...
Most faxes and MFP (multi function printers) can be set not to print the confirmation page with every fax. All these settings and many more can be found it the User Reference manual that came with the printer if you can't find yours one is available here:
http://www.fixya.com/support/p378618-hp_officejet_6110_all_in_one_inkjet/manual-3613
Page 37 "print reports" is what you're looking for
Nov 16, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I forgot the code on my xerox fax confirm f116
Check menu,8,2. You may be able to print out the road map on the different menue configuration.
You should be able to print out by
selecting menu ,*, 8 and printed with Menu, "*", 1.
Not seeing the machine is difficult to see the different ways the menus are going to.
Technical parameters are different and has a different enter mode. This needs to be researched further for explination.
Good luck, this may take a lead in the right direction.
Nov 12, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Xerox F116 fax drum & toner reset cards
This would be an expensive process event to try an old card when entering a used modual. The card resents the main board the the card cannot be used again.
If anything else send the cartridges back to Xerox.
If you try to experiment with a new card, and an old drum, chances are you will create new problems for the Xerox repairman to fix.
Keep a new supply of toners and drums and make sure each item has the card in the box, and do not allow the customers or casual operatiors, including Managers!!!! , to swap theses items on their own.
They are too expensive to trouble-shoot and experiment with.
Good luck.
Sep 22, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Status Code 19
Look in you menus. Your log print out is probably set to on and set to print out way to frequently. You can turn that feature off.
You can go to Xerox.com, click on Support and drivers. In the search box type in 116 then go to support and then type in Log, There should be an answer there as to how to shut off log printing. You cold also type in code 19 when you get to the support page.
May 05, 2009 | Xerox FaxCentre F116 Plain Paper Laser
My faxcenter is completly blokked
Hello
Does it have paper jam or other problem?
Please check the appropriate link.
How to clear paper jam.
Fax problem
Other problems
Best regards,
Zizzler
Apr 23, 2009 | Xerox PRINTERS - FAXCENTRE 2121 21PPM LSR...
Hi how do I turn of tx and rx reports on faxcentre F110/
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
  • With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
  • Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
  • Always: a report is printed after each successful or interrupted transmission.
  • On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
  1. Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
  2. Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
  3. Press [OK]. The transmission report screen will be displayed.
  4. Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
    NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
  5. Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Dec 11, 2008 | Xerox FaxCentre F110 Plain Paper Laser
Incoming faxes from multiple locations jamming our machine
I believe there should be a "Clear memory", or "dump fax Memory", in the menu selection.
Press reports and scroll to machine print out. You should get a print out on the machines configuration and help menu to better assist you.
This should dump the memory so you can prepare yourself for new incoming faxex.
Dec 08, 2008 | Xerox FaxCentre F116 Plain Paper Laser
How to add the fax from the xerox fax-center f116 into my network?
here is the driver, try installing it.
it picked up the machine as a plug and play, but Vista does have some problems so..... try it
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=F116_F116L&Xlang=en_US&Xcntry=USA
good luck
Dec 14, 2007 | Office Equipment & Supplies
Xerox FaxCentre F116 Plain Paper Laser Logo
221 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
