Back to:
Tags:
JVC 3 Way Speakers Car Speaker
Speaker-Eating dashboard?
By Riddle - usenet poster
My Mazda 626 seems to have an appetite for speakers.
I have replaced the passenger's side front speaker for the third time a
couple weeks ago, and already it's buzzing like a bee is trapped in it.
The speakers installed are capable of MORE than the rated wattage of the
JVC Cd player (~22 Watts per channel, speakers are 50W or more)
All the other speakers work great, including the Driver's side dash
replaced in January as a set with the one that went bad a couple weeks ago.
There aren't any leaks, there doesn't appear to be any 'stray magentism'
anywhere around, no obstructions or protrusions of any type into the
speaker area.
I'm out of 'inexpensive' speakers (the last one that blew was a Clarion,
not the most expensive, but not a cheapo by any means...) Connections are
tight.
Usually audio problems don't throw me, but this one has me stumped.
Any ideas?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Bouncy
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
What size are these speakers?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Speaker-Eating dashboard?:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Gary10
Rating: 0%, 0 votes
If the one side is failing, swap the good and bad speakers. does the
bad speaker become good? and the good speaker turn bad? is the stereo
properly grounded?
Thank You!
Solution #3
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
you sure about that? it's true that distortion tears up speakers, and an
underpowered amp can lead people to crank the volume up beyond clipping,
but i've never heard it suggested that the amp be rated for more power
than the speakers.
Thank You!
Solution #4
Not Rated (0)
Odud
Rating: 0%, 0 votes
You need more power. A good rule of thumb is that the amp should be
rated at 2 times the speaker rating. This prevents clipping which
speakers apaprt.
Thank You!
Solution #5
Not Rated (0)
Perkins
Rating: 0%, 0 votes
Hachiroku wrote:
50W continuous? I have some 2' tall floor speakers rated for 50W
music power but only 1W continous (instructions said not to exceed 8V,
peak-to-peak, for more than 2-3 minutes).
If you don't blast them at high power all day, about the only
electrical thing that usually ruins speakers in a hurry is DC from the
amplifier. Switch a digital voltage meter to read DC volts and see if
there's more than about 0.1Vdc across the amp terminals (an analog
meter won't work for this). Don't measure to chassis ground because I
think that most car stereos now use two floating outputs (an easy way
to get higher power without higher power supply voltage).
Have you tried pressing the speaker cone to see that it moves in and
out without binding? Some of my Ford factory speakers (base audio
system) that scraped the magnet when moved also buzzed, but I had a
Ford radio cause a buzz because of some power supply problem (I think
it was the power supply that drove the LCD).
Thank You!
Solution #6
Not Rated (0)
Peter1
Rating: 0%, 0 votes
Find a cheap speaker, hook if up electrically but don't install it
physically. Just extend the wires and leave it somewhere in the car to
figure out whether it is related to the physical installation or a short
from the radio.
Thank You!
Can you Help with these Car Speakers and Subwoofers problems?
car radio code for nissan pathfinder 2000
mitsubishi montero car radio unlock need help
When I try to play my ipod on the pioneer avic 900bt I get...
how to connect digital cap pc2.0f
my battery went dead in my car and my head unit wants a...
Loading problems.
Repair Service
Find Car Speaker and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
