Question about Toshiba Satellite Pro M15-S405 Notebook
Phillips 40" lcd Connect my pc via DVI
I have an nVidia graphics card with dual output. 1 VGA and 1 DVI.
I have a DVI to HDMI as the tv only has this option for connecting to it.
I have demonstrated dual monitors with the setup as is, but cannot get anything on the tv it just keeps reporting video not supported.
Please help
    Sniper:
  • 65 Answers
This most likely means that your lcd doesn't support the resolution that your laptop is displaying.
Posted on Mar 21, 2009
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Mar 26, 2015 | Lenovo ThinkCentre Computers & Internet
How to connect asus p1801-t to tv ?
This PC is equipped with a NVIDIA GeForce GT 630 2GB DDR3 VGA/DVI/HDMI PCI-Express Video Card. This means if your TV has an HDMI input connector you can directly connect the pc to the Tv with an HDMI cable and select the corresponding graphics monitor connection in the Display properties. Alternatively if your tv has only got a VGA input that can also be used from the PC and you can connect the speaker or headphone audio output to the audio input of the TV with a suitable 3.5 headphone to RCA adapter.
Aug 24, 2014 | Computers & Internet
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
Will my 64mb GF2 support dvi and / or hdmi connection (I want to get a flat panel monitor)
Not directly......but no worries!
All hope is not lost with just the VGA out on your card!
First, every flat panel monitor I have ever seen has a VGA input, so your GeForce2 card will still work!
VGA is still the top analog signal standard for computers. I am writing this with my on-board NVIDEA GeForce, connected to a Viewsonic VA2226w flat panel monitor using VGA and set at a resolution of 1680X1050!
Almost forgot..... just ignore the "TV Out" on your card.... this is old school and will give you nowhere near the quality you will get from VGA.... it was meant as a "crowd pleaser" to allow people to connect to their old school big screen TV sets.
Get the flat panel display... you will find out that it will work just fine with your VGA connection.
Feb 19, 2011 | Nvidia GeForce2 MX400 Graphic Card
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
How to connect Samsung 40" LCD tothe eMachine desktop T2615. It looks like there is only one connection for a monitor? The computer is about 6 years old.
Older LCD TV's have a variety of inputs, one of them being VGA, to connect to your PC. The problem seems to be that you either connect your PC to its own monitor, OR to the TV, but not both? If that's the case, you may have a couple of alternatives:
The most expedient one would be to get a VGA splitter cable; the other, more expensive: replace your video card with one that has dual outputs: either one with two DVI ports; one with one DVI port and one VGA port; or one with one DVI port and one HDMI port. As you can tell, there are several possibilities, depending on the connectors available on your TV.
Sep 08, 2009 | E-Machines eMachines Desktop PC
Graphics card hdmi output to monitor digital input seems to not be working
i am having a problem with my sound and i need sound driver for dell dimension 2350
May 22, 2009 | Gigabyte Computers & Internet
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
Toshiba Satellite Pro M15-S405 Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
