Question about Sony Walkman WM-D6C Personal Cassette Player
Sony Walkman cassette player/recorder will not rewind the tape
I have a Sony Walkman WM-D6 Professional machine from the 1980s, very little used and in almost brand new condition. However, the rewind/reverse button has suddenly ceased to function so that the machine now only runs forwards and the tape cannot be rewound.
It records and plays perfectly in all other respects.
Is this a simple mechanical malfunction that is easily remedied or something more complex in the electronic controls?
  • Anonymous Mar 16, 2009
    have used the player very little and not for a long time. Same problem occurred suddenly. Wonder whether the rewind and fast forward (cue) are belt driven because the mechanical movements seem to happen and every other function works
    Problem Solver:
  • 11 Answers
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Posted on Feb 26, 2009
  • Dave May 28, 2009
    I beleave that, that puticular unit has a little belt that drives the FF/REW functions if I'm not mistaken and has a play foreword rubber drive flywheel that sometime needs replacing especally when it gets pitted !
    Electronic Doctrors eledocs@hotmail.com
    Problem Solver:
  • 15 Answers
Io sono in grado di ripararlo, ho riparato molti wm-d6 e wm-d6c migliorandone anche le prestazioni con alcune modifiche. Contattatemi alla mia email doctor.walkman@gmail.com e sar? lieto di aiutarla. I am able to fix it, I have repaired many wm-d6 and wm-D6C also enhance the performance with some modifications. Contact me at my email doctor.walkman @ gmail.com and I'll be glad to help.
Posted on Oct 10, 2010
The recorder was not used for a while. All functions work well except rewind and cue.
Ho riparato molti d6,d6c e altri walkman di alta gamma, aumentando anche le prestazioni se richiesto e se possibile. La mia email: doctor.walkman@gmail.com I have repaired many D6, D6C Walkman and other walkman high-end, improve your performance if required and, if possible. My email: doctor.walkman @ gmail.com
Oct 03, 2010 | Sony Walkman WM-D6C Personal Cassette...
My nephew connected my Walkman Pro WM-D6C to a 20V laptop power ada[pter. Needless to say there was a spark and it no longer runs. Is there an internal fuse that has blown or is the problem likely to be...
I have repaired many D6, D6C Walkman and other walkman high-end, improve your performance if required and, if possible. My email: doctor.walkman @ gmail.com Ho riparato molti D6, D6C, e altri walkman di alta gamma, aumentando le prestazioni, se richiesto e se possibile. La mia email: doctor.walkman@gmail.com
Sep 09, 2010 | Sony Walkman WM-D6C Personal Cassette...
My Sony Walkman Professional WM-D6C will turn on but the take-up spindle just slowly inches the tape along in short bursts, not a continious action.
Contact me at my email doctor.walkman @ gmail.com, I'll ask you some questions and some photos of the WM-D6C in his possession. We will solve the problem
Apr 23, 2010 | Sony Walkman WM-D6C Personal Cassette...
The power is on but the motor will not turn the tape drive. Does anyone know a good repair shop?
Hmm, when you press play, can you feel the motor turning, do the spindles turn on fast forward or rewind? If so you may have one of two problems. First check to see if the cue button is is depressed. If it is jammed, the deck will FF and RR but won't play. If it's not that, but the motor still spins, the motor is no longer making contact with the flywheel. If you have a repair manual, dismantle the deck and check out the motor contact
May 10, 2009 | Sony Walkman WM-D6C Personal Cassette...
Sony tcd-d8 won't rewind
sounds like a belt slipping try renewing them they are fairly cheap to replace.sony tend to be very reliable but this is quite an old item now and belts degrade with time and use.farr64
Apr 30, 2009 | Sony Walkman TCD-D8 Personal Cassette...
Sony Walkman cassette tape player operating at slower speed
If this is the WMD6C then it is servo locked and can be fine tuned with the pitch control on the back of the unit just turn the switch to on then adjust to preferred speed.
Dave, Electronic Doctors email eledocs@hotmail.com
Mar 31, 2009 | Sony Walkman WM-D6C Personal Cassette...
My Sony Walkman WM -SR10 is not recording and the cassette tape is not working. Only the radio is player. And I cannot get another one to buy even its not the same. Can you help me
Hello aga2958,
I think you need to visit maintenance center to fix that cause its hardware problem.
But you can check somethings before u visit them .. like:
1. If you are using Batteries to power up the Walkman .. be sure the batteries are full charged.
2. Try to power on the Walkman by Adapter 3 Volts.
3. Be sure the tapes you are using are fine into other Cassette.
Thanks for using FixYa.
Nov 09, 2008 | Sony (Personal Audio) Walkman AM/FM Stereo...
Plays too fast
WMD6C has a pitch control on the back of the unit that can change the speed of the tape, so switch it off, but if that is not the problem then inside the unit it has a servo set speed pot on the main board.
Nov 08, 2008 | Sony Walkman WM-D6C Personal Cassette...
Tape fails to return to cassette when cassette removed.
I'm an repairer of electronic and micromeccanaca I have repaired many walkman analog (WM-D6C, wm-dd9, etc.. Improve your performance if required and if possible) and many like dat walkman Sony TCD-D3. I just started to repair even for those who come out of Italy. If you would contact me to explain the problem better I'll try to help. Email: doctor.walkman@gmail.com Sono un riparatore di elettronica e micromeccanaca ho riparato analogico walkman molti (WM-D6C, WM-dd9, ecc. Migliorate le prestazioni, se richiesto e se possibile) e molti come dat walkman Sony TCD-D3. Ho appena iniziato a riparare anche per chi si trova fuori d'Italia. Se vuoi contattarmi per spiegare meglio il problema cercher? di aiutarti. Email: doctor.walkman@gmail.com
Jul 29, 2008 | Sony Walkman TCD-D100 Personal Cassette...
Sony Walkman WM-D6C Personal Cassette Player Logo
1,653 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
