Question about Genius Wayne Submersible Sump Pump With Switch
Pump runs too long
I have wayne 3/4 horse switch genius pump whis is new. keeps on sucking air and will not shut off for several seconds making terrible air sucking sound thruout the house it is so loud. I have leveled the pump and it is free and clear of any obsticles. what can I do to get this to shut off after the water is gone without several seconds of this.
  • 3 Answers
Install a float switch that will switch-off the pump once the water reaches its level.
Posted on Mar 09, 2009
2 Suggested Answers
SOURCE: I have wayne 3/4 horse switch genius pump whis is
You can raise the switch in relation to the pump to ensure that shut off occurs before the pump starts sucking air. Somewhere between 1-2" ought to do it. The switch is attached to a 'spindle' on the pump through 2 holes in the switch. I unscrewed the spindle so that I could take the top switch hole off of the spindle while leaving the bottom hole on. Then I screwed the spindle back in. This allowed the switch to be raised in relation to the pump. I drilled two small holes in a plastic part near the top of the pump & secured the top hole of the switch to the pump body with string. Crude, but effective.
Posted on Mar 13, 2010
Where can I get an automatic pressure regulator as I was given the compressor without one and have to keep turning it on and off manually.
You need a pressure switch. In Ft Wayne go to Wayne-Vaughn. Bring the size of the motor, pump type model number and serial number.
Feb 27, 2016 | Air Tools & Compressors
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Are the genius switches any better than the float switches?
If you are placing a sump pump in a smaller, more confined area then yes. They both have their downfalls, and either can fail without notice. The ones that slide up and down the rod can get stuck or jammed, sometimes even due to build up on the rod. I tend to favor the genius switches, but either needs to be checked out periodically.
Oct 31, 2009 | Genius Wayne Submersible Sump Pump With ...
Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
Jul 14, 2009 | Genius Wayne Submersible Sump Pump With ...
No information on Wayne 55701-RP1
This isn't a valid Wayne pump model number according to Wayne's website. Please double check your pump and visit:
http://www.waynepumps.com/producttype.aspx?pt_producttypeid=8
May 23, 2009 | Wayne Water Systems Wayne RECONDITIONED...
I have wayne 3/4 horse switch genius pump whis is new. keeps on sucking air and will not shut off for several seconds making terrible air sucking sound thruout the house it is so loud. I have leveled the...
Feb 23, 2009 | Genius Wayne Submersible Sump Pump With ...
Genius Wayne Submersible Sump Pump With  Switch Logo
518 people viewed this question
Top Genius Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Genius Electrical Supply Expert? Answer questions, earn points and help others
