Question about Tools & Hardware - Others
Magazine cover for airy nailer
Need a transparent magazine cover for airy brad finish nailer # ATT-0241S
  • Anonymous Mar 21, 2014
    Have DeVILIBISS SHBN4 brad nailer need repair kit NSK-005.
  • 313 Answers
Airy no longer has a home base in the USA. E-bey might be your best option
Posted on Sep 08, 2009
My nt50ae2 brad nailer jams in the magazine. the feeder rides on top of the nails.
This happens. The follower jumps over the nails and the magazine binds.
Step 1. Remove nails, unplug hose.
Step 2. Remove the bolt at the bottom of the magazine with a 2.5mm hex key.
Step 3. Remove the magazine while holding the nail follower in place to the magazine cover.
Step 4. Carefully remove the nail follower and gently extend the yellow warning indicator and follower spring.
Step 6. Inspect the nail follower. There should be 3 indentations that are stamped into nail follower face. This is the culprit.
Step 7. With a small punch, make these three indentations deeper.
Step 8. Assemble and test. Repeat if necessary.
Hope this helps.
Jul 28, 2012 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
TNT XAGD50 brad nailer is jammed
If the jam is bad enough you may just have to pull the 3 front magazine screws (metric allen screws) and the one in the rear that holds the magazine to the tool frame. That way you can pull the entire magazine off which will expose the nose area and you can remove the jammed nail.
Jul 28, 2012 | Sears TNT 3 gal Air Compressor with 2 in...
My brand new DC608 18 gauge nailer jams every time on the 2nd nail.
Per your addendum I would have first told you to check that you are using the proper guage nails. Second you should make sure you are loading the nails in the lowest channel in the magazine so they are at the bottom of the magazine. If you load them into the top of the magazine they have more time to go off course before they get into the wood.
May 29, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
How do I load the 2 1/2 inches nails to my 16 ga porter cable finish nailer? How do I put the oil and what part of the gun?
You need to open the nail magazine and you just load one strip of nails at a time, then close the magazine. It will have a spring putting pressure on the nails, so it will have resistance on it and it will increase as you close it.
The oil gets dripped in the air hose connection on the gun before you connect the air. Make sure that this gun actually takes oil, some newer guns are oilless.
Hope this helps,Matt
Dec 10, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
I only shoot one nail and the rest is air. i need to push up the magazine to advance another one. This is my first finish nailer, is there something i'm doing wrong or is it the gun. I just purchased this...
Possibly, I would make sure that you are using the right guage nails first with the proper collation. You can go to Dewaltservicenet.com and download a breakdown for the tool and also a users manual.
Jul 19, 2010 | Dewalt D51256K 16 gauge finish nailer kit
Help! My finishing nailer seems to have stopped driving the nail, period. It sounds like it is working but I am not sure if the hammer is even pulling back into the driver enough to actually drive...
It sounds like your gun has jammed. The fix isn't hard. First, though,make sure that your compressor is putting up sufficient pressure. Most of my jams happen when I drive brads and forget to turn the compressor back on! If the pressure is good, you'll need to check for a jammed brad. Disconnect the gun from the compressor. Pull back the slide and remove the brads from the magazine. At the front of the nailer, you'll find a cover, close to where the brads exit the gun. Open the cap and it will reveal a tab that will give you access to the nailing slide. Your gun probably came with allen wrenches, and they may be located on the gun, or in the case. Mine are along the slide, tucked in, and look like a part of the gun. You'll need an allen wrench (most likely) to remove the two allen screws that hold the cover assembly to the gun. Remove the screws, making note how the piece comes off. With the piece off you should be able to see where the brads come to the nailer from the magazine. Look for a hung up brad here. If you note a silvery piece of metal in front of the magazine, fear not, that is the hammer slide. The compressed air powers the slide down, peeling a brad from the magazine and driving it in. If necessary, you can gently press the slide back up. Try not to bend it. Locate the jammed brad(s) and wiggle them out of the gun to clear it. Sometimes it is easier to push them back into the magazine and shake them out. It takes a little finessing to get it right, but perservere. Reassembly is the reverse of the break down. Oil your gun daily. I put a few drops of oil into the air inlet at the gun before I connect the air line, and then drive a few brads into scrap wood.
Hope this gets you going on your project.
Best regards, --WoobieDog--
Jul 10, 2009 | Porter Cable Air Tools & Compressors
Airy brad nailer ATK 0250S
ereplacementparts.com. see if they have a schematic for this gun. Good luck sound like a head cap seal.
May 28, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
You should be able to find a local Dewalt/Black and Decker service/repair shop and they will be able to sell you all the parts you need, I would recommend getting a full upper rebuild kit and replacing everything, while you have it open already
Mar 15, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Tools & Hardware - Others Logo
308 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
