Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
My Phaser 8200 is displaying the code:
15,004.45:50425
Any ideas as to what this may be and how to fix it?
Thanks a million!
Steve
  • Anonymous Mar 03, 2009
    Is it expensive to replace these halogen lamps?
    President:
  • 2,072 Answers
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Posted on Feb 28, 2009
Phaser 8560DN Printer ~ Error Message
An error code due to the print head, check the waste tray area for a spill, has the printer been moved lately? remove left cover and look for spill.
-Carl, please let me know if this helps.
Jun 25, 2009 | Xerox Phaser 8560DN Printer
Xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Jun 23, 2009 | Xerox Phaser 6250 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Printer error 15.004.45.433219 on Tektronix Phaser 860dp
Hi juniorgona:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850 and 860 have a pre-adjusted head.
Hope that this helps.
Apr 08, 2009 | Office Equipment & Supplies
Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Jan 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Error code 09,036.44:10394
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Sep 15, 2008 | Xerox Phaser 8500N Printer
Error code 09.037.45:35532
That is a yellow ink stick count fault.
Most likely one of the yellow sticks has just gotten twisted in the loader and not advancing. May be cracked or damaged but for some reason not sliding down to the bottom and hitting the sensor.
Check the sticks and if you need to remove them just take a screw, like a drywall screw and twist it into the block to remove it.
If you managed somehow to get a stick in the machine from a different phaser product, it is shaped different and would not actuate the switch at the bottom of the ink loader.
Aug 04, 2008 | Xerox Phaser 850DP Thermal Printer
Phaser 8560 mfp code error
Thanks for your assistance, but I found out the machine is still under warrenty and is scheduled to be fixed.
LeRoy
Jul 11, 2008 | Xerox Phaser 8560MFP Laser Printer
Printer error meaning
I found a couple of references to the error ?07,010.43?, it?s a generic message with lots of possible causes. Xerox?s official web site says to turn your printer off a contact their technical support. I did find one reference that said for them it turned out to be a wiper assembly stuck between the print head and the roller. I?ve never owned a Xerox printer (I?m an HP guy) so I can?t help you beyond that. Xerox?s support site for the phaser series is here: http://www.office.xerox.com/color-printers/phaser-8500-8550/sprt-enus.html
Dec 04, 2006 | Xerox Phaser 8550DP Printer
Xerox Phaser 8200 Laser Printer Logo
88 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
