Question about Fisher and Paykel GWL11 Top Load Washer
Washer constantly goes out of balance
GWL11 washer, 4 yrs old. Goes out of balance 1 out of 3-4 times. Flannel sheets, flannel shirts, towels, fleece, jeans all mess it up. Pull all out, move around and retry, maybe yes, maybe no. Pulled the top of washer, checked level of drum, checked tub support springs, tilted washer to check under for leaks, etc. All ok, no noise, no leaks. Will spin fast if it can get to that cycle with out going off balance, Checked oobal switch seems to work ok, will stop spin manually. Other times works just fine. What is going on? used to work great with any load, problem happened just recently.
  • 70 Answers
1 option is to wind the back feet out so the washer drum will sit more to the front so as it less likly to hit the OOB switch, other thing is that the OOB switch might have corrosion on the inside of it and in this case if it gets moisture inside it during a wash it is more likely to go OOB, so try replacing it this should fix issue, if not replace Motor Control Unit. :)
Posted on Feb 28, 2009
What covers are there for standard dog beds?
Most of the standard dog beds are covered with materials such as fleece, flannel, denim, microfiber or faux suede.
Sep 06, 2012 | Allied Precision Dogs
What materials are standard dog beds covered with?
A standard dog bed is typically covered by fleece, denim, faux, flannel, microfiber, or suede.
Aug 29, 2012 | Anima Dogs
LG Washing machine leaks from the bottom when large items such as flannel sheets are placed in the machine. It does not leak at any other time but I had water all over the floor twice when I tried to wash...
Water may be working its way up and over the inner wash tub with the larger items. Ensure that you are not overloadinig the washer. You may want to contact an appliance service company.
Feb 22, 2010 | LG Washing Machines
Spin cycle tub becomes unbalance
When the drum gets unbalanced more often then not, there's a few things to check:
1. Check to make sure your machine is level. Check level from side to side and also front to back. The machine has leveling feet to adjust. Make sure they are all in firm contact with the floor when leveled.
2. Wash items that are alike in material. In other words, wash towels with towels, shirts with shirts, etc. If you wash a load of shirts with a towel, it will have a tendency to get unbalanced quickly.
3. Avoid over-stuffing the machine and washing under sized loads. Both of these scenarios will cause a tendency to go out of balance on the spin.
This will solve 75-80% of unbalance issues. Let me know how it goes..
Dec 07, 2009 | Maytag Atlantis MAV6451 Top Load Washer
What numbers are the knobs supposed to be set on?
Flannel is a light - mid weight fabric. If your tension dial goes to 8 , set your tension between 3-5ish. Try that and just tweak it to either side to get a smooth stitch on either side of yhour fabric.
Apr 15, 2009 | White Sewing 1409 Mechanical Sewing...
Maytag Washer MDE7400AYW goes off balance while spinning about half the time. Walks across room. Springs are OK. Tub seems very easy to move from side to side by hand.
Typically when the drum spins and walks the washer, it is a loading issue.
As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load.
THis is especially prevalent in loads that are:
1. small,
2. contain lots of towels and
3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
Nov 07, 2008 | Maytag Washing Machines
Kenmore 80 series model no. 110.26842691
Your agitator may be fine but how is your washer behaving is it trying to perform two acctions at one time like spinning and agitating at one time the tarnmission may be locked up
Jan 21, 2008 | Kenmore 24032\24036 Top Load Washer
Nexxt 100 Series Washer
seperate sizes of clothes towels with towels shirts with shirts. if the washer gets unbalanced and cant balance itself it will shut down after ex amount of trys. your owners manual does discuss this in the trouble shooting section
Nov 08, 2007 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
251 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
