In my new Town Home, the builder has provided a hanging light on the side of the living room. I want to move this to the center of the room and possibly put a new lighting unit.
How easy is it to move the existing fixture from the other part to the center. The distance is about 4 feet (between the current fixture and the center of the room).
Sorry, was in a hurry. you need to attach a cable of the same gauge as existing, to the wire snake and pull it back into the existing outlet box from the new location
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
2Pansy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
If you have 20 inch joists, they must be trusses, this is good as it allows you to snake cable in two directions. You can get a retrofit fan/chandelier outlet box such as Westinghouse 1100 from electrical supply or HD. with this box, you just cut a 4 inch round hole in the ceiling and the bar and box goes up and expands to the joists, but before you install the box, shoot a wire snake from a knock out of the existing lighting outlet to the new location. Once you've installed the box and fixture, splice the cables together in the existing box, and install a flush black plate like "invisoplate" which is barley noticeable
Was this helpful?
Yes
No
Solution #3
Perkins - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
There is no attic on top. Its in the middle level with about 20" joists, so I may have to cut a circular hole for the new fixture. I want to reuse the existing switch/wiring of the other light fixture, so, I can probably close it off after I move it to the center.
How easy or hard is it to accomplish this
Thanks
SR.
Was this helpful?
Yes
No
Solution #4
M0nica L - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
You got a few variables involved: What's the ceiling made of? Is there attic above it? Do you want to eliminate the current ceiling outlet?
Was this helpful?
Yes
No
Popular Solutions for Westinghouse Newtown? Ceiling
Torpedo heater won't light. Glow plug is on, and nozzle is spraying fuel, but refuses to light. ...
(More)
Torpedo heater won't light. Glow plug is on, and nozzle is spraying fuel, but refuses to light. Pressure is set to 4.7 per specs.
Replaced receiver and remote for Hampton Bay Windward II ceiling fan. Fan has only one speed in...
(More)
Replaced receiver and remote for Hampton Bay Windward II ceiling fan. Fan has only one speed in forward or reverse even though I am cycling through the speeds.
I have a flameright ISIS which will not switch on, . I get a very slight flicker when its plugged in...
(More)
I have a flameright ISIS which will not switch on, . I get a very slight flicker when its plugged in and the nothing. I have replaced the battery in the remote, I have moved the switch inside the remote fully to the left, back fully to the right and then back left one notch. Stilll no good. Any ideas? The dial on the back of remote is set correctly.
It's a stealth model with a remote control. It was running a few days on "Winter" -- very...
(More)
It's a stealth model with a remote control. It was running a few days on "Winter" -- very low speed. One morning I noticed it had quit. Nothing worked with the remote. What's my problem?
