Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Nothing on printer works
Top of 5500 printer fell over backward, pulled ribbons and sheared wires. Is this falt covered by warrenty? Terry Smith 1202 N. Fir Beebe Ar. beardwh@yahoo.com service # F241644
  • beardwh Feb 23, 2009
    I consider the problem a manufacturing problem. I have been told by others that it is a commom problem of the support catch not working and allowing the top half of the printer to flop over.
    Genius:
  • 1,605 Answers
You can try to contact Kodak support, if the printer is still under warranty (13 months from the date of purchase of date of manufacture.)
the answer is probably not. It is not manufacture defect.
Posted on Feb 23, 2009
  • Frank
    Frank Feb 23, 2009
    if that is the case, call the customer support and have them replace the top. we can't do that for you here.
The glass of scanner hp2510 is broken how can i remove it and fix it
I can tell you how to get access to the glass panel, although I cannot remember how easy it is to remove the glass itself:
First remove the lifting lid by unplugging the jack plug connector at the back, then riase the lid to vertical position, pull the plastic tab in the middle of the hige towards you and wiggle the lid upwards so that it comes out. Then pull off the keypad label plate, then gently pull off the control panel (which has two ribbon cables attached) by sliding it forwards from back to front of the printer. Disconnect the ribbon cables from the control panel (they pull off) and thread the cables back through their retaining clips on the top cover. Now you can remove all FIVE retaining screws (Torx T-10 driver required) from the top cover and lift it off, leaving the ribbon cables in situ. You can then turn the top cover over and work on removing/ repairing the glass. I would say it s not worth bonding - just get a new piece of glass.
Mar 25, 2013 | HP PSC 2510 All-In-One InkJet Printer
My canon mx410 printer won't turn on
I had this problem before, just open the cover, pull out the cartridges, it wont pull by itself, cause there is no power, so pull the wire!!!, remove the cartridges and turn the the power! it works!!!
Nov 13, 2011 | Canon Pixma MX410 All-In-One Printer
Smith Corona Elctric Type write D 5500 Memory. Requires printing tapes
If you are asking what ribbon this takes, it is the SCM H series ribbon. still readily avail.
DickyO
Sep 22, 2011 | Smith Corona Office Equipment & Supplies
Printer is just stop so i can not see little green light and i cant print nothing look like no electric but we have pover power goes in the printer i check the little fuse is ok to so what can be aproblem
Check the ribbon. On mine sometimes tha ribbon gets caught by the impact wires and snags. The printer stops functioning when this happens. Remove the ribbob carefully; pull it free from the impact wires. Turn the printer off and on again; it should work.
Dec 06, 2009 | Matrix Star SP200 Receipt Printer
1035 ricoh aficio printer with error code 322
Yes, the code is caused by toner getting into the laser unit. The laser unit likely only needs to be cleaned out. To do so, turn the machine of with the red rocker switch on left side of the machine. You will need to remove the front cover and the brown cover behind it. The mechanical counter is plugged into the brown cover so be careful not to damage the wires. The laser unit is the black plastic case you will see behind the brown cover. Be sure to remove the necessary screws and connectors. Be extra careful of the ribbon cable, it kinks easily and the contacts are easily damaged. The Laser unit will slide out, and you can remove the screws holding the top cover on. After removal, clean the interior of the case and mirrors. Do not use any liquid to clean it, preferrabley canned air and a lint free cloth. After cleaning, reassemble, turn the machine back on, and test.
Nov 19, 2009 | Ricoh Aficio 1035 Copier
How can i remove the ribbon cartridge of EPSON LX-300+ii?
open the top cover and pull up the cartridge if ribbon stock near head pull properly...........
Oct 09, 2009 | Epson Dot Matrix LX-300+ II Printer
Smith Corona Classic 12 ribbon won't stay in place
Okay...i had the same problem when I replaced the original ribbon that came with my Classic 12. I think it was the ribbon that came with the typewriter.
Anyway, on the ribbon carrier, there are two sets of metal prongs on top of one another. If you get the ribbon behind both of them, it will pop up and not go back down or won't come up at all.
You have to get the ribbon between the two sets of prongs. There's isn't much room and you have to kind of pull the bottom of the ribbon taught and slide it down from the top.
It isn't easy the first time, but after you get it, you won't forget.
As for your ribbon not feeding...take the spools out and make sure the pegs that go into the holes in the spools are rotating when you type. This is what moves the spools. Then make sure you're getting the pegs in the hols when you put the spools back in.
Also, make sure the ribbon isn't twisted anywhere and that it's threaded correctly. Both spools should look identical with the ribbon coming out of the top toward the carrier.
To ensure you have the correct ribbon, got to the Office Depot online store and do a search for Smith Corona Classic 12 and you will get a pretty generic, double-black ribbon that fits and works perfectly...and is so soaked in ink you can reuse each side three times. I don't recall the brand name, but the box is grey with red lettering.
Apr 16, 2009 | Smith Corona Office Equipment & Supplies
Printer will not turn on
You have already answered you own question. The ribbon wire holds about 30 wires in it. they all have to be seated in perfectly or it won't work for you. Take it to a computer store and see if they can re-seat it for you. Probably 30 bucks for labor to fix.
Jan 05, 2009 | Lexmark X75 All-In-One InkJet Printer
Replace a ink caetridge
Open the " top access door" wait for the carriage to go to the center, pinch the latch of the inks located on lower part facing you.
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
New printer set up
rang kodak direct there is a falt with a part of the printer so they are sending a replacment as it is still under garantee .lets hope this works.
Apr 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
27 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
