Question about Zyxel Prestige P-330W Wireless Router (P330W)
Unable to connect my wifi laptop to my existing wireless b/band
I'm using a Zyxel NBG334W wireless router connected to my desktop and that connection is fine. (OS is XP)
tried connecting my wife compaq laptop using the wirelss connectivitiy and it won't connect - it says the settings saved on the laptop do not match the requirements of the network? (OS is Vista Basic)
i do not know what i'm doing or what needs to be changed - can anyone help?
    Scholar:
  • 141 Answers
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Posted on Feb 23, 2009
Zyxel P 660HN T1A as a wifi router to be connected to a modem
Website says its 802.11n Wireless ADSL2+ 4-port Gateway, so yes.
May 27, 2013 | Computers & Internet
Hi. i have the zyxel P-600 series. i have it connected to my desktop and i am able to go on the Internet using my desktop. i used to be able to go on the Internet using my laptop as there is wireless....
you need to check if you have the wirelees hot spot enabled
do it following the next steps
1- Press the WPS button on the nbg-417n, you should see that the wlan led blinks 2- Check that your wirelees adapter is enabled in your lap
then it should connect to the net
if you still have issues check the next document http://www.zyxel.co.uk/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420081028103616
Mar 22, 2011 | Zyxel NBG-417N Wireless Router
I have zyxel nbg334w bought before xmas 08 can connect pc to internet with it but although wireless laptops and games consoles find it still wont connect i am connected to internet via virgin media...
Had the same problem connecting zyxel NGB334W to XBox 360. Other computers and devices would see the SSID but the XBox 360 would not. I had no luck talking to the techs at zyxel, they said it was incompatible with the wireless XBox device. Good news!!! This can be resolved. I went into the setup (192.168.1.1) / Wireless Lan / Advanced / Wireless Advanced Setup. Under the 802.11 mode set to 802.11b. Factory is 802.11b/g and this was not seen. Hope this helps you out.
Jan 30, 2009 | Zyxel Prestige 334 Router
Zyxel nbg334w router configuration
Hi
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
Configuring nbg334w router
ipconfig /release
ipconfig/ renew
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Installing wireless router
um is it compatible with vista and/or upgradable?
Jan 15, 2008 | Zyxel Prestige P-330W Wireless Router...
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
ZyXEL Wireless set up.
First many current PC models have switches to power on the wireless feature. Do you have one of those and did you power on the wireless.
Second wireless devices communicate on four different bands A, B, G, N. Some devices support multiple bands. Does your wireless router/access point (maybe a Zytel p660HW-D1 from above) support at least one of same bands as your laptop built-in or purchased wireless adapter? If you do not know post the manufacturer of the wireless router/access point, laptop if the wireless is built-in or wireless adapter if it is a separate device and I will check that for you.
Dec 26, 2007 | Zyxel P660HW-D1 Router
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
Zyxel Prestige P-330W Wireless Router (P330W) Logo
464 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
