Back to:
Tags:
Gateway MX8711 PC Notebook
MX8711 Notebook
By Reynolds - usenet poster
Has anyone purchased an MX8711 17" notebook? We are interested in it. We
would like to hear any impressions, positive or negative. TIA
carl
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 03, 2007
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The only problem I have experienced is with the shutdown function. I contacted Gateway. It was shipped out, fixed (very quick, friendly customer service) and I haven't had a problem since.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on MX8711 Notebook:
I don't want to Accept this solution
Solution #2
posted on Aug 02, 2007
Not Rated (0)
Ross
Rating: 0%, 0 votes
I have seen other people reporting on the same issue, the different
processor. One person mentioned that there was a note on their box that
stated that the PC should not be sold before January 30. I wonder if the
machines with the T2250 processor were early release machines before the
T2060 was fully in the pipeline. The T2060 appears to be surrounded by
mystery. The only information on it appears in a pdf table of all the Intel
processors and it is shown in its own category. It appears to be a Core Duo
with a smaller cache, however it is referred to as a Pentium.
In any event, I have the proper processor, the T2060 as reported by the
bios, by Windows and by the system information in Microsoft Works.
Thank You!
Solution #3
Not Rated (0)
2Pansy
Rating: 0%, 0 votes
I just got this laptop a week ago, and I have been very satisfied with
it for the most part. I agree with the 17 inch monitor. It is
borderline non portable. But the numeric keypad is helpful. My
biggest complaint is getting used to Vista, but that's not the Laptops
fault.
I also found discrepancies with the hardware and what Vista reports.
I noticed that Windows shows 2 different CPU models. In the Device
manager, it shows an Intel T2@1.6 GHz which is what the specs
show. But the BIOS, System Info, and other programs in Vista show an
Intel T2@1.73GHz. I also downloaded CPU Info, and it showed the
T2250. I tried getting in touch with Gateway to find out which it is,
but they said it may be a problem with Vista. I don't buy it. Not
with the BIOS showing a different chip. I just checked the Device
Manager and it also says the 945GM chipset.
If you get a chance, check your processor, and let me know what it
says. Thanks.
Thank You!
Solution #4
Not Rated (0)
Phoebe
Rating: 0%, 0 votes
Well, we received ours yesterday. My initial impression is very positive.
First reaction, this puppy is big. As we are basically using it as a
desktop replacement (that can be moved from room to room) the size and
weight are not great issues, however someone looking for a portable device
would probably want to go with a smaller screen.
Gateway took advantage of the added width with the 17" screen and put a
"full sized" keyboard on the unit. Although it is more compact than a
standard desktop keyboard, I love the layout with the separate cursor keys
and number pad.
Interestingly enough, Microsoft Vista reports a different chipset than
Gateway claims for the unit. The Gateway specs call for the Intel 943GML
chipset. Vista reports that the laptop is using the Intel 945GM chipset
which appears to be a more robust and mainstream chipset.
Basic setup was easy. After allowing the laptop to go through its setup
routine, it only took moments to get the laptop on our wireless network and
to get it to recognize the network printer. I haven't had an opportunity to
browse through the software much, but it appears to be pretty standard,
Microsoft works 8.5 and a trial version of Office 2007 Student and Home
edition.
This laptop looks like a keeper, the special that Best Buy was running with
it, made it a bargain at $700.
Thank You!
Can you Help with these PC Laptops problems?
Ok, I have seen posts about this subject, however I cannot...
i cant get my 10 key pad to work....its like the numbers...
did you ever find out what is going on i just started...
how do i go about taking out the hard drive? my note book...
door locks continuously locking when car is running but...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
