Cannon Canon i960 Photo Printer Logo
A
Anonymous Posted on Mar 10, 2013
Canon irc 2620 is not printing
I downloaded the driver but i still get printing errors
Copy Solutions Ltd
Level 1:
  • Contributor 22 Answers
  • Posted on Nov 27, 2014
Copy Solutions Ltd
Contributor
Level 1:
Answers
22
Questions
0
Helped
8479
Points
38
You need a PCL driver , down load it from Canon.co.uk\ Support, but if it has a Fiery on the back, then you will need a postscript diver, same site.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
2answers
Officejet 2620 wont print
I Have hp office jet 2620 its working perfect.
every time when i ON the printer every time its print alignment page and then ask to scan it.
How i close this option can any one help me.
Zahid Azeem
3helpful
Canon iRC 2620 error code E000020-04c0 Any ideas?
The error code E020 refers to a density problem with one of the Drum Units. The sub-code 03b0 refers to one specific Drum Unit, of which
I'm not sure. I believe if you go into service mode and check Density, you'll see each Drum Unit listed there. You are looking for an average Density reading of +-2.5 for the Units. Don't get crazy trying to reach that value, but look to see which one is way off and that may be your culprit. Or maybe one of these other guys may be able to tell you which unit the sub-code is pointing to.
IRC 3220 Color Copier when printing pdf files is very slow. A 2 page document takes 2 hours to print. please help.
Hello pd.
I suggest you remove and re-install your print driver and make sure you install the CANON UFRII print driver available at the Canon web site. Also, Adobe 8.0 has a known problem with this and you can go to their website and they have a patch for this problem, I hope this helps.
E 000732-0001 IN CANON iRC 3200 .
Here are some possible solutions
getfile.asp?rid=1258 March 3, 2009 getfile.asp?rid=3215 Product : imageRUNNER C3200 / 2620 / 3220 Title : E732 and E733 are Displayed, when Copying off the Glass or when using the DADF
Error :
Error codes of E732 and E733 are displayed, when copying off the glass or when using the DADF. The Control Panel would go blank and the processing data light would continue to blink. After a few minutes in this state; the copier was rebooted and the codes would resolve themselves, but would eventually return.
Workaround :
First, try reseating all the connectors to the Reader Controller, Interface PCB, and DDI-S PCB. Next,
check for proper voltage to all three boards.
In this case, a defective DC Fuse PCB caused the error codes. An intermittent loss of voltage to the Reader Unit caused the machine to code out.
Note:
The part number for the DC Fuse PCB is FG3-3020-020.
Canon USA, Inc. Systems & Technical Support Division
I have 3 color copy machines irc3200n,clc 2620 all the machines
the cause of the problem is ,the transfer belt is not rotating properly ITB rollers must cleaned throroughly (cleaned by isopropyl alcohol) to prevent slippage of transfer belt that causes mis alignment /misregistration of color,but copying BW is ok,In other words ITB unit needs servicing ,Run also gradation adjust QUICK and FULL adjust (for IRC 3200)
3helpful
2answers
SErvice Manual IRC 2620 please
A irc3200 Service Manual will give you mostly the same info - there are very minor differences. You can get one here
2answers
ERROR CODE E00002-0102
You have a fuser problem. You didn't specify a machine but if it is the irc/clc3200/3220/2620 you will need to replace the fuser unit. If you have a different model where the fuser thermistors/thermal fuses etc can be replaced then replace according to the manual.
Canon Copier Sevice Manuals
Top Cannon Office Equipment & Supplies Experts
NOEL
NOEL
Grand Canyon Tech
Grand Canyon Tech
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
