Question about Whirlpool GU2400XTP Built-in Dishwasher
There is water in the bottom of dish washer after finishing. If I start another cycle, everything drains, so it's not a problem with the hose. I hear water draining. I think it is the drain time. When the machine was under warranty, the service guy came and changed the drain time to longer. He told me how to do it, via the buttons, but have now forgotten where I put such great information. I have a 1996 built in model.
  • 50 Answers
We have come up on this many many times. It is not drain time. There is a flapper in the drain hose located where the hose attaches to the pump with towels remove the hose and stick you finger in. It is and angled piece of rubber so it will be difficult but you will feel a flapper. Press lightly on it and make sure it is positioned so that is open freely when you press thus the water will move freely.
Posted on Feb 26, 2009
Can you show me the diagram on how the spray arm is to be attached with the locking nut...kenmore dishwasher model #665.15752000
Posted on Feb 23, 2009
Dishwasher washes dishes but does not dry even though that display shows dry icon
First ,Check for a water puddle on the bottom of the dishwasher .If you have water there, you more than likely have a plugged drain or drain hose, or bad drain pump (less likely) If no water is there see if the dishes are hot after a cycle. If they are not you could have a bad heater (that circular thing on the bottom of the dishwasher) other problems could be the timer or computer Depending on the model brand and age of the dishwasher .One last thing there is a vent to let moisture escape that could be bad but then you would have hot wet dishes
Aug 07, 2014 | Blomberg Dishwashers
Water did not drain from the bottom
Hello Cheryl, There are a couple of possibilities. When the dishwasher drains the dirty water it is a time based function. This leads me to believe it is a blockage or partial blockage in the drain hose.
Here is an example. (If your dishwasher drains into your garbage disposal) washing dishes you put scraps into the disposal and forget to turn it on after you are done. The disposal is filled with scraps this restricts the flow of dirty waterfrom the dishwasher. If the flow is restricted less water is being drained per second from the dishwasher. This is why the dishes still looked clean and there was still water in the bottom of the dishwasher.
(if your dishwasher drains into a drain pipe) there is blockage or partial blockagein the dishwasher drain hose. if the sink drains slowly the blockage is in the main line
Hope this helps
Joe Connolly
Nov 02, 2011 | Frigidaire Dishwashers
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
When cycle is finished there is residue on dishes and water left in the bottom of the dishwasher - it is also slow to start
I would guess that you are washing your dishes in diluted mashed potatoes  :)   The dirty water is not being pumped out so that fresh water is used to rinse the dishes   your hose may be pinched  or your pump may need to be replaced   also your drain hose should be installed so as to rise to the underside of the counter and then drop down to the drain connection on your sink.   This allows the water to siphon out and makes less strain on your pump  but also help leave some water in so that the sensitive plastic parts inside don't melt from friction.  being slow to start is an ordinary feature of many dishwashers... i can't help you there.
Nov 08, 2009 | Computers & Internet
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Kitchenaid dishwasher will not drain completely model kuds25shwh1
there is a plastic cover in the back over the drain under the dish tray,, pull out the tray and in th back of the dish washer there you will look down and see a small strainer that is plastic, you will need a 1/4 inch nut driver to remove the cover,, after you remove it there is a couple of pastice peices to take out that are just laying there, remove them and there is a small blade that is there to help cut up food that has been left behind on the dishes,, you can remove this and under it you will find the drain hole,, clean out any debris that is in there, if you have to you might want to take tha bottom cover off the lower front of the dish washer take off the drain hose and flush water thru,, adfter this and then reinstalling everything the way it was, run the dish washer if it still has water sitting in the bottom it is time to get a new pump, it is bad and not pumping,,, you may wish to have an appliance person out to tackle this job,, good luck
Jan 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Hoover optima AAA1600 hntf 6167 washing machine
Most washers have a drain hose that is mouted high to keep the water in. If you drop the hose to floor level it will drain with out help. Be sure you have a floor drain or bucket. Then check the belt on the motor if there is slack it will not engage the pump for drain to operate. Need to tighten the belt.
Mar 25, 2008 | Indesit W 123 Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Whirlpool GU2400XTP Built-in Dishwasher Logo
145 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
