Question about Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
My poulan (wild thing) chainsaw won't stay running! I've put new gas @40:1 ratio and a new spark plug.It's fairly new.Don't know whatelse to do!
  • 3 Answers
Sounds like you are starving for fuel. This can be a clogged fuel filter (old gas around the outside of it), a cracked fuel line, or the diaphragms in the carburetor need replaced. Make sure you the fuel filter is clean. Clean it off with some gumout spray. If your fuel lines are not cracked, then I would suggest a new diaphragm kit in the carburetor. Not sure of your mechanical abilities, so I don't know how hard or easy that would be for you to do.
Jeff
Mowers4u
Posted on Feb 25, 2009
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wild Thing 18" chainsaw model 952-051338 Spark
Spark plug size= 3/4 or 19mm. Champion RCJ--7Y gapped to 0.025.
Fuel mix= synthentic 40:1.
http://www.manualsonline.com/ex/thread/view/idThread/3524133
Sep 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need to have a manual on this wild thing so that i know the right ratios for the gas.
This Chain Saw requires a 40:1 gasoline to oil mixture. This is typical for all 2-cycle motors. More information can be found here:
http://www.ehow.com/how_4464807_fuel-poulan-wild-thing-chain.html
Aug 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
New spark plug fresh gas new filters no spark
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
If you replaced the plug, did this and still have no spark you have a bad coil.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Nov 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
Nov 15, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
534 people viewed this question
Top Poulan Tools & Hardware - Others Experts
L Pfaff
L Pfaff
Bill Boyd
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
