Question about Whirlpool LER4634J Electric Dryer
I went 2 turn my elect whirlpool dryer on,1st it tripped the breaker,i flipped it & it will nt start up,its getting power..though
  • 40 Answers
If your getting 240v to your dryer but will not start and is tripping breakers there are a few things this could be I would start by making sure your cord is in good condition and the terminal block where the power cord is connected to does not look burned or at your wall plug.
Posted on Feb 23, 2009
Kenmore Series 80 Dryer won't start after Circuit breaker was tripped
A breaker thrown that many times indicates a serious electrical problem. You need to have the problem taken care of by an electrician. You should be worried about the safety of yourself and your family.
That being said, I would guess that breaker has gone bad and needs to be replaced.
Dec 18, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
I have a whirlpool electric dryer.. when I turn it on its been having a problem with staying on or not heating at all. It will spin and stay on but no heat.we have changed the element and it seemed fi
Sounds like a tripped circuit breaker in the power panel for the house. The breaker for the dryer is actually 2 breakers connected together so if one trips so will the other. Sometimes this does not happen and only one breaker trips. This condition removes power to the heating element but still supplies power to the rest of the dryer. Check to see if the breaker will reset by turning off and back on several times. Then check the power receptacle that the dryer plugs into with a voltmeter set to read 240 volts AC. If no 240 but 115 is present then replace the circuit breaker.
Nov 19, 2014 | Whirlpool Dryers
I inherited an older model whirlpool electric dryer when I moved in...there seems to be no heat...went to get clothes out this morning and they were still damp...I wasn't given a manual - and have...
Check the breakers, by FULLY turning it off and then back on. What happens, commonly, is the heat side of the 220 breaker trips. If it keeps happening, sometimes you need a new breaker, but DO NOT increase the amp rating of the breaker. Breakers that trip from time to time, eventually start tripping EARLIER.
Jun 10, 2011 | Whirlpool Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Dryer wont turn on. Breaker in breaker box is fine. No light inside dryer. What's wrong?
Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work now? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
Sep 20, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer won't start, none of the breakers were tripped. I flipped all the breakers anyway. Where to start
Unplug unit
Unplug wires to start switch
Check the start switch for continuety with a meter
Mar 06, 2010 | Whirlpool LER4634J Electric Dryer
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Whirl pool elect dryer keeps tripping breaker
Ok, this is the result of a failed High limit thermostat. you should replace this failed device asap.
Check for continuity in the thermal fuse as well. replace if no continuity is found.
May 31, 2009 | Whirlpool LEB6300 Electric Dryer
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
