Question about Cfm Daikin R410a Split System Air Conditioner
How to insert oil in outdoor of split type airconditioner
I have 18000 btu split type airconditioner,hitachi model with R22 ,due to leakage it has lost all refrigrant ,I have all equipment to insert r22 my question is this do i also need to put oil in unit if yes then how much and how to put oil,can i put oil from suction side or is there any other way to do so ,kindly explain it to me comprehensively,Thanks in advance,my email is ,
  • me3992003 Feb 24, 2009
    Thanks for your kind attention and reply sir,I am a hobbiest and it is my passion to learn about things,I have fixed the leakage ,and amount of r22 to fill in unit is written on its tag its about 1.2 kg,i also have pressure meter and digital scale to check exact amout, but my question still remains that what is method to put oil in unit for future problems ,and what should be the amount ? can i put oil from suction side or anyelse method and when do a compressor really need oil?
  • Anonymous May 10, 2009
    My air conditioner sounds like it rattles and grind alot now----I thought it jsut needed oil. Any advice?
  • 144 Answers
You shouldn't have to add oil. The little bit that leaks out with refrigerant isn't significant. I would be more concerned about the leak itself. Has it been located and fixed. If not it will no doubt leak out again. Also do you know how much refrigerant to put in the system? Have you vacuumed the air/moisture from the system etc. Is the system totally flat or is there still some refrigerant in it? Let me know so I can advise you correctly.
Posted on Feb 24, 2009
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
R22= 70-80psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Send a message to me on Facebook at Connectors Audio and Video Services page. Panasonic is a brand I carry and will do some calling for you. Please include the model number.
Oct 31, 2014 | Panasonic CU4KS24NBU 24,200 BTU...
What does error code E6 mean?
E6 usually means that there is a communication problem between the indoor unit and the outdoor unit. This could be due to a wiring problem or maybe you had a momentary drop in the voltage. Find the circuit breaker in the circuit breaker panel for your home/office that is connected to the A/C unit. Turn it off and back on and try using the A/C again. Sometimes the indoor unit is connected to one circuit breaker and the outdoor unit is connected to another one. Make sure you have disconnected and reconnected both before running your unit. If that does not solve the problem you may need to have some cable replaced between both units.
Apr 30, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Hello Sir,I want to buy two engines for the blower of split type model AC 18000 BTU , two remote control and two electrical panel of same model.Kindly send me the quotation of the articles and the...
Hello Sir,I want to buy two engines for the blower of split type model AC 18000 BTU , two remote control and two electrical panel of same model.Kindly send me the quotation of the articles and the shipping cost through DHL and normal shipment .Its urgent. I have already sent this mail to Mr Tom several times but he has not reply me. Hope you will reply me and do the needful because I need the parts urgently for my client.I have bought the AC from your company and I am facing lots of difficulties with my client because of the parts are not available .Regards Sameer Sobratee
Apr 25, 2014 | YANCHENG AOCHI Solar Air Conditioning Wall...
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
The best pressure of gas in a split ac in
65 psi is the ideal pressure remember its not exceede from this pressure.
and it is valid for all season
Jun 05, 2010 | LG LSC121PMA Split System Air Conditioner
Split Airconditioner
you can add oil to unit from suction valve but you have to know how much == you have to remove the cmopressor drain it of oil and add the countity that wrighten on it between 500 and 750 cc appro
as i understand your question when you know that the comp needs oil change
its when it is over heated or work at high temp
so you can hear a noise or an usual motor noise
i wish it ok
Feb 24, 2009 | Cfm Daikin R410a Split System Air...
Cfm Daikin R410a Split System Air Conditioner Logo
913 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
