Question about GPX DV-1010 DVD Player
Old gpx dv-1000 dvd player stops playing halfway through movies
My gpx dv-1000 dvd player stops about halfway through a movie when ever i watch one. also whenever it freezes i cant open the drive, stop the movie or anything so i just unplug the player altogether. i was thinking that it is just overheating and needs air circulation. any help is appreciated. thanks!
5 Suggested Answers
SOURCE: GPX d2816 problem
hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
Posted on Aug 21, 2007
konzzz
  • 255 Answers
SOURCE: GPX PD808B dvd player has no picture. its all white.
portable DVD's encounter that problems more often.because of its folding action,the flat wire connecting the screen to the DVD board breaks and causes no picture.try to open it up and check it or bring to a tech.
Posted on May 28, 2009
SOURCE: Region hack needed for GPX PD907B DVD Player
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
Posted on Dec 06, 2009
SOURCE: Gpx pd750w don't show movies on the usb stick what
I have tested mpg, avi, wmv and no luck yet.
Posted on Dec 07, 2010
MY DVD NOT PLAYING DVD MOVIES BUT PLAY AUDIO
The laser pickup assembly will often play CD's but will not play DVD's this is a sign the assembly is failing, far cheaper to replace the player.
Mar 10, 2012 | GPX D1816 DVD Player
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
Jul 23, 2010 | Durabrand PDV-705 Portable DVD Player
My Sony RDR-VX530 VCR/DVD player/recorder just stops playing
play a lens cleaner cd in it,,, it will work smoothly
Apr 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
No sound from new Pioneer DVD player
try resetting defaults
Place DVD player in standby mode
Push in the stop button on the hardware unit and keep pushed in
Push in Standby button on the remote provide while doing the above
Then put into standby mode again insert your DVD and see if it changes.
All Happiness
Apr 08, 2010 | Pioneer DV-333 DVD Player
Freezes halfway through the movie
Use a good dvd cleaner & clean the player. If this works then problem solved, if not then check the back of the dvd for deep scratches. those are the two common causes of the problem you describe. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Pioneer DV-260 DVD Player
Valor IDA 700w won't play movies
TRY CONECCTING THE BLACK/GREEN CABLE TO GROUND
Nov 21, 2008 | Panasonic DV-169 Valor DVD/VCD/CD/MP3...
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
DVD player
Clean the pickup using a commercial cleaner disc.That's the only quick,cheap fix.
Dec 12, 2007 | Toshiba MW20FM1 20 in. Combo
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
GPX DV-1010 DVD Player Logo
366 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
