Question about Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch dischwasher is not draining completely. I've taken out the mesh filter and the square plastic drain cover. Should I unbolt the white cover which I presume covers the drain? thanks!
I had the same problem, twice. Both times, the technician simply removed the drain hose and cleared it of a small food particle. Save yourself the service charge by unhooking the hose yourself, clearing it and rinsing your dishes THOROUGHLY before washing.
Posted on Feb 27, 2009
My Bosch 300 does not have a little round plate nor a square plate below my drum opening on the exterior of the washer like many posters have indicated. How do I get access to my drain filter?
These Bosch machines are similar to some Kenmore washers (he4t). You can remove the lower front cover. Behind this cover, you will find a white plastic housing that has a s tree off cover. Be ready with a catch pan! Remove this cover and water and collected debris will come pouring out in a large gush. If this becomes clogged, the washer may send error codes and fail to spin and drain properly. You can fish out additional debris with your fingers before replacing the cap and the lower front cover.
Nov 10, 2016 | Bosch Washing Machines
Water is clogged in the bottm of the unit. how do I clear the drain?
The drain filter is clearly visible at the bottom of the wash compartment but there are several possibilities as to why there is still water in the bottom of your washer:
1. Blocked drain filter
At the bottom of the wash compartment, there is a fine mesh grille and a plastic cylinder which protrudes from it. Grip the plastic cylinder, twist anti-clockwise and pull it upwards. To clean it, remove any debris from the cylinder, rinse then replace in reverse order of the above.
2. Blocked/kinked waste hose
Check the waste outflow hose at the back of the washer for any kinks or other damage. Also remove the hose where it attaches to your sink (or waste outlet) and check for any blockages.
3. Blocked waste disposal / sink trap / waste outflow
Make sure your sink is draining efficiently. Clean as necessary
4. Faulty waste pump
If all of the above check out, you may have a faulty pump. Please post back for further advice regarding this after completing the above checks.
Regards,
BElectric
Nov 11, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
DISHWASHER DRAINING POORLY
Check to see if you have a plugged, kinked, drain hose or screen. Do you know how to disassemble the bottom of the diswasher to get access to the drain hose? Also, is the dishwasher drain and hose properly vented?
Aug 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Siemans dishwasher not draining
the water in the bottem of the machine under the mesh filter is normal. it acts as a lubricant for both motor impeller and drain propeller. if its greasy then try using only 1 tablespoon of powder soap from now on. now if the water level is ever above the mesh filter after a complete cycle, then you have a drain problem
May 25, 2009 | Dishwashers
WATER DOESNT DRAIN
I had the same problem. I took out the filter and cleaned it, scooped out as much water as I could and poured some sink unblocker into the bottom of the washer, followed by some hot water. After leaving it a while I took the plastic mesh cover off, and removed and cleaned all the bits I could (will be different on different washers). Then I put it all back together and ran a quick wash, and it worked. I did a couple more washes with it empty in case there was any cleaner still lurking. Result - one unblocked (and sparkly clean!) dishwasher. Hope this helps!
Mar 11, 2009 | Bosch SHV68 Built-in Dishwasher
Sink was pluged plunged and now the dischwasher will not fill it's keeping draining the water out all the time
Bosch has a safety float switch under the dishwasher basin. If water leaks into this area, the float rises and turns on the drain pump to clear out the water in the dishwasher. Hope I explained that ok :)
Anyways, usually a leak somewhere causes this and unless the leak is fixed and water is removed or evaporates, the dishwasher will remain in the drain cycle.
Feb 24, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Genral oil change
Look for the oil dip stick. Now look under underneath the area of bike where the dip stick is. You'll see a round disc with a bolt. That is the drain plug. Now you found it lets begin.
1. Warm the bike up.
2. Turn bike off.
3. Take oil dip stick out.
4. Have your oil pan under the bike
5.. Unbolt drain plug. A spring and screen will come out keep them together.
6. After oil finished draining. Make sure Screen is clean before replacing back in with the spring.
7. Start the bolt in by hand then finish with tightening with socket.
8. Put oil dip stick back in. you're ready to go!
It takes 15W 40 ( .9 liters) Don't forget to press yes if this was helpful : )
Nov 10, 2008 | 2005 Kymco Grand Dink 250
Genral oil change
1.Get your supplies ready and expose your engine 2.Unscrew the Oil Filler Cap 3.Remove the Oil Drain Plug 4.Remove and Replace the Crush Washer 5.Clean the Oil Drain Plug 6.Remove the Oil Filter 7.Remove and Clean Plastic Mesh Filter 8.Lubricate the O-ring of the New Filter and Attach it to the Engine 9.Motorcycle Oil Change - Replace Oil Drain Plug & Plastic Mesh Filter Pour Oil 10.Check the Oil Level,,
Nov 10, 2008 | 2002 Buell X1W lightning White
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
226 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
