Question about Dell E173FP 17" LCD Monitor
I can't see all of the screen at one time
The screen requires that I scroll to the right and left to see all of the information - changing the screen resolution on the control panel doesn't seem to help. I've been working on this for hours. Please help! I'm sure it's a simple fix - I just can't get it!
    Genius:
  • 1,605 Answers
The Dell E173FP is one of the cheapest in their line, and is fairly good value for money, the panel only has a Vga input so the image
quality isn't quite as good as it could be with DVI input.
unistall any video card that you have installed. use the VGA output on the back panel.
The monitor maximum resolution in 1280x1024 although it can be run at down to 640x480. When it is at anything but its native resolution the image looks a little distorted and washed out as it is stretched to fit the screen. When at native resolution it has a good picture though, clear and fairly bright, although maybe a little darker than other screens with a brightness rating of only 250cd/m^2, compared to an average brightness of 4-500cd/m^2 on recent panels.
so with say, there is not much you can do to adjust the screen to the best you can and make sure the frequecy is set at 60Hz.
Posted on Feb 23, 2009
Son forgot password for game console. how do I reset it or get it fixed.
To reset the pass code follow these steps:
  1. Sign in using your Xbox Live-enabled gamertag.
  2. Scroll right to settings and select Account.
  3. Scroll right to Your Information and select Account Security.
  4. Select Change Password.
If that doesn't work you can always reset the console to factory settings by following these steps:
  1. Scroll left on the Home screen to open the guide.
  2. Select Settings.
  3. Select All Settings.
  4. Select System.
  5. Select Console info & updates.
  6. Select Restore factory defaults.
  7. Read the warning message, and then select Yes.
Dec 31, 2015 | Microsoft Xbox 360 Console
Tip
How to set/ change time on your Polar F11.
Having trouble setting the time with your Polar F-Series watch, here is simple quick step-by-step guide to follow.
First know your buttons:
upper right - Scroll
lower right - Scroll
center right - choose
lower left - reverse/ back/ stop
upper left - light
#1 - Push the center right button (exercise will appear)
#2 - Push the upper right button (settings will appear) use the upper right or lower right buttons to scroll if neccessary
#3 - Push the center button (a menu will appear)
#4 - choose Watch, use the upper right or lower right buttons to scroll if neccessary
#5 - Push the center button to choose watch, once highlighted
#6 - use the upper right or lower right buttons to scroll through the watch menu
#7 - Choose Time
#8 - Continue to use center button and scroll buttons to choose and set.
Important button to know - the bottom left button is a reverse button. Make a mistake, just tap that button, keep tapping to go all the way back to the main menu.
on Dec 22, 2010 | Polar F11 Heart Rate Monitor
Tip
How to set/ change time on Polar F6.
upper left - light
#7 - Choose Time
on Dec 22, 2010 | Polar F6 Wrist Watch
Install oovoo
Changing the screen size on an Acer computer, whether it is a laptop computer or a desktop computer, is a simple task.
You can adjust the screen size to be larger or smaller.
If your eyes hurt from concentrating on tiny letters all the time, you should make the screen smaller.
If you have to scroll left and right to read sentences in a document on your computer, you should make the screen larger, at least to the point where you do not have to scroll left and right to view the entire window.
Go to the desktop of your computer and right-click the screen.
Click the last option, which is "Properties."
The "Display Properties" window will now show up.
Click the "Settings" tab in the "Display Properties."
Adjust the meter under "Screen Resolution."
When you move the meter to the left, the screen becomes smaller.
If you move the meter to the right, the screen becomes larger.
Click "Apply" to save the settings once you are finished adjusting the screen resolution.
http://www.marthas-web.com/display.htm
Jul 13, 2013 | Acer Aspire One PC Notebook
My apple is disabled, how can you help me?What happenned?
Your iPod most likely has now been disabled because you forgot your passcode.
Step 1: Connect your iPod to your computer with the USB cable that came with the iPod.
Step 2: Open up iTunes and scroll down on the left side of the screen
Step 3: Choose your iPod, your right screen should now change to show some general information about your iPod.
Step 4: Scroll down on the right side of the screen until you see a button labeled "Restore". Click it, and it will unlock your iPod and reset it. This will wipe everything off of your iPod, but will sync it back with whatever you have in your iTunes library.
Feb 04, 2011 | Apple iPod touch
How to remove date stamp from screen?
In the lower left corner of the back of the camera just to the right of the LCD screen is a button marked "disp" by pressing the button it will change the different screen modes on should show only the picture without the numbers or writing on it.
Dec 26, 2010 | Canon PowerShot SX20 IS Digital Camera
How do I set the time?
For a complete manual visit my tips and tricks page.
The time is under: Settings>Watch
To access settings push either of the right side buttons from the main default screen
Push the red button
use the right buttons again to scroll to watch
Push the red button
Right buttons again to choose time
Push red button
The Right side buttons scroll through choices, the red button is your chooser/ confirmation button. The left side bottom button will return you to a previous screen.
All other settings can be changed in the same way.
Dec 09, 2010 | Polar S150 Heart Rate Monitor
I also have a Magellan Triton 300 and I can not change it to my time zone.. how can I change it?
From the user manual at http://www.magellangps.com/assets/manuals/MagellanTriton_300_400_500_UserManual.pdf
it says:
Setting the Time Zone
The time and date information will be computed from information from the GPS satellites so there is
no requirement for you to input any time or date information. However, to make the time accurate
for your location you must select the correct time zone.
1. From the Map screen press MENU.
2. Select View.
3. Select Settings.
4. Scroll down and select Date & Time.
5. Select the Time Zone field.
Press button
momentarily
Fundamentals
5
6. From the drop-down menu, select your current time zone. (Time zones are not changed
automatically when travelling. If you travel to an area with a different time zone, you will
need to change it here for accurate time information.)
7. Repeat the process for the Daylight Savings field.
8. Press ESC when done.
Jan 02, 2010 | Magellan Triton 300 Handheld GPS Receiver
Tomtom one europe
Power up your tomtom. On the Map screen . Tap the screen , then select " change preferences " , Then scroll right until you see the " Lips " icon , Select the "Lips" under it , it says " select voice " . once in there , you can scroll left or right allowing you to choose the voice / language you require . Hope this helps.
Sep 06, 2008 | Tomtom One Europe v2 GPS Receiver
Syncmaster 245bw monitor resolution screen and resolution issues
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Nov 25, 2007 | Samsung SyncMaster 245BW Monitor
Dell E173FP 17" LCD Monitor Logo
77 people viewed this question
Alun Cox
